Question about HP DeskJet D1460 InkJet Printer
How do i change ink cartridge 21 in hp deskjet D1460 printer
I want to know how to remove old ink cartridge and replace new one in HP Deskjet D1460 printer
  • HP Master
  • 2,404 Answers
Here is the manual for your printer courtesy of HP:
http://h10032.www1.hp.com/ctg/Manual/c00905267.pdf
On page 47 of the manual it explains how to change out the cartridges.
Let me know if you need more help.
Posted on May 23, 2009
Sir I have HP Deskjet -D1460 and my black cartridge not printing
In most cases the printer driver software can have errors while being in use or is shut down. First remove the ink cartridges, the B&W . Now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 17, 2011 | HP DeskJet D1460 InkJet Printer
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
My HP deskjet d1460 is showing offline after cleaning the print cartridges. How do i rectify the problem?
Possible that the drivers were corrrupted , hence to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 21, 2011 | HP DeskJet D1460 InkJet Printer
I have a HP 1460 printer & I have now no black ink in my printer.can this printer support any duplicate cartaige(local cartaige)?
No, that printer only uses the 21 Black and 22 color cartridges. The best thing to do when you run out of ink is to buy a refill kit and then refill each cartridge at home. This saves lots of money in the long run. Click on the link below to view a refill kit for your HP D1460:
http://cgi.ebay.com/Refill-ink-HP-21-Deskjet-1420-1430-1460-BK-4oz-s-/320621581336?pt=BI_Toner&hash=item4aa6891418
Feb 13, 2011 | HP DeskJet D1460 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
My HP Deskjet D1460 is printing very very faint lines. Can you help?
cartridges is a newly installed or old one...if old is about to be empty just replace with a new one...
Oct 27, 2009 | HP DeskJet D1460 InkJet Printer
HP Deskjet D1460 I have lost my printer CD
Click the link below to download all the required drivers. You will then be able to install these drivers and use you r printer again:
HP Deskjet D1460 Drivers for Windows XP
HP Deskjet D1460 Drivers for Windows 2000
HP Deskjet D1460 Drivers for Windows Vista
Note: These files are greater than 50 MB.
To install: Remove any old HP Deskjet D1460 drivers and you printer cable from your pc and install the driver first. Connect your printer when the driver software asks you to.
Sep 11, 2009 | HP Office Equipment & Supplies
HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Jun 16, 2009 | HP DeskJet D1460 InkJet Printer
I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
May 28, 2009 | HP DeskJet D1460 InkJet Printer
HP DeskJet D1460 InkJet Printer Logo
297 people viewed this question
Seeker5211
Seeker5211
