Question about Pool & Spa
Suction line replacement
Hayward pump is has suction leak and I need to access suction line attached to inground skimmer. How big a hole do I need to cut in concrete deck?
  • garysr900 May 25, 2009
    Thanks for your response, David. I could use some clarification. If I want to remove the skimmer while getting to the suction line, how much clearance would I need to cut on either side of the skimmer and how much clearance in the rear of the skimmer? Thanks again! Gary
    Perfect! Thanks, David.
    Gary :-))
  • 59 Answers
We cut a 12" hole.
David
Posted on May 25, 2009
  • David Lowry May 25, 2009
    when a pool is installed an area about 2'x2' is left for the skimmer. It has a spout that is about 8 inch's from the front of the skimmer to the pool. If you just want to dig down behind the skimmer, you will need to cut about 1' back from the bqack of the skimmer to give room to dig under the skimmer and get to the suction line. David
Pool skimmer has too much suction after changing to PVC pipe.
if you only have a skimmer and no valve to direct suction from the skimmer to he main drain, you will nee to down size your pump, i suggest a hayward 3/4 hp super two pump
Apr 29, 2013 | Pool & Spa
No suction from hayward large filter system.
Suction loss is due to one or more of the following;
  • Skimmer wier stuck in upright position
  • Water level too low
  • Clogged skimmer baskets
  • Obstruction in suction line(s)
  • Breech in suction line
  • Missing/ cracked/ dried out pump lid o-ring
  • Pump pot basket full of debris
  • Clogged impeller
  • Broken pump seal
These account for 99% of suction loss problems, it may require a bit of detective work to find the problem.
Mar 16, 2013 | Hayward 36 Sq Ft Pro Grid Vertical Grid De...
How do i drain my inground pool with this system
Valve off your skimmer(s) so only your floor drain(s) is open and set the valve to waste. Your pump should then drain the pool out the backwash line assuming nothing leaks and the valve effactively shuts off any skimmers.
John
Apr 10, 2011 | Hayward SAND FILTER, PRO SERIES
I presently have a Hayward EC 60 (yes 60) pool filter and a 1 horse power motor.. It works well but it does not support the new Pool Vac cleaning robot I purchased. It supported my old Pool Vac, but not...
if you buy an adaptor,should be a 1 1/2" dia hole,in the bottom of the skimmer, put it in the skimmer hole,put your vac line on that, turn the valve to it's on full skimmer, it will work,
thats a nice filter,pool guys will sell you anything!
esp at this time of year!
buy the minumum!
Sep 13, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
When i put my hose in to vaccum i lose suction but with out hose it will **** your hand down the pump is workin great
Are you filling the hose with water before you put your hose into the skimmer? Put your vacuum in the pool - put the other end of the hose over a discharge ... when the air bubbles stop coming from the bottom ... , put your hand over the end of the hose and then stick the hose into the skimmer suction.
Jun 04, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Pump won't **** when attach the hose
Its very possible that it is not a problem with the pool pump, but a problem with the conncetion to the vacuum hose. If you are losing pressure only when you vacuum, make sure that your connection is secure and you have no holes, cracks, etc. in your line. If you think that there are definate pool pump problems, check for the following problems.
1) Clogged or restricted strainer or suction line
2) Plugged or restricted discharge line of filter (high
discharge gauge reading).
3) Air leak in suction (bubbles issuing from return fittings).
4) Pump operating underspeed (low voltage).
5) Plugged or restricted impeller.
May 31, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
NOT FILTERING, NO SUCTION, CHANGE SAND,,,SINCE DAY ONE..WRONG HP?
You are correct. Your lines are extremely small for this system and the pump is to small for this system. You are going to have to do a total upgrade. from the pump to all the lines. I know this is bad news, but it is a common problem for system that where put in more then 10 years ago
Jun 01, 2009 | Hayward SAND FILTER, PRO SERIES
Loses suction after 2 hours
Filters are getting blocked.
Clean more offten - use filter socks (if have skimmer box).
OR get better pump/filter system.
May 31, 2009 | Hayward 1HP Super Pump II Inground Pool...
Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Apr 28, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
208 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
