Question about Nintendo Wii Console
Wii will not turn on no power
I haven't used the wii for about a week and now it's pugged in and it won't turn on. The machine is only used by two adults and it's less than 6 mos old. HELP
  • 1 more comment
  • herrera8 May 24, 2009
    Yes thank you. It finally worked upstairs I guess you can't leave it plugged in all the time.
    Problem Solver:
  • 11 Answers
Check if everything is plugged in
Posted on May 24, 2009
Suddenly, why can't I change stitch length?
If it is a mechanical machine, it most likely has seized due to lack of regular cleaning and oiling.
The following may be helpful:
The feed dog knob won turn don think anything is broken haven used the...
Dec 31, 2015 | Sewing Machines
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
Dec 30, 2015 | Sewing Machines
Can not hook the TV up to the Wii, it won't come in, I have a new RCA TV . The back of it has a orange color pug in not a yellow and I pug it in and I also don't know what setting to put it on
A newer TV may mean that your wii is not setup to use the proper resolution(HDTV). Are there 1, 3 or 5 RCA ports on the back of your tv?
Some tv's have more than 1 set of RCA ports..are there no ports on the side of your tv? If so, try those instead.
If you have 5 ports only, you may need to use the green one for the yellow cable. This might result in a black & white image, and will be used purely to change your wii settings to use a higher resolution.
OR try this: Nintendo Customer Service Wii No yellow video AV input on your TV
Sep 17, 2015 | Nintendo Wii Sports Resort
Wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Situation Not Resolved:
If the system still won't power on, the system and AC adapter will need to be repaired. To start the repair process, click here.
Wii Console Turns On, But Has No Power Light Situation:
  • The power LED on the system does not come on, but the system still powers on and plays
Information:
If the Wii Console is still working normally, it is likely that the power LED is broken.
This issue will remain limited to the Power LED, and will not get any worse.
Unless the system is having other problems, continue using the console regularly for a few weeks to determine whether this interferes with the enjoyment of game play.
If, after using the system for awhile, the Power LED not coming on is too distracting, the Wii Console does carry a one-year warranty.
We are happy to inspect and, if necessary, fix the system at no charge within the warranty period. To start the repair process, click here.
function rvl_ts_sys_power_no_light_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_power_no_light",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_power_no_light_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) } function rvl_ts_sys_power_no_light_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_power_no_light=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_power_no_light_techDif(){ //it broke document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_power_no_light_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_power_no_light_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) }
Dec 25, 2011 | Nintendo Wii Console
My wii won't turn on
Information:
What To Do:
Dec 23, 2011 | Nintendo Wii Console
Cant connect to wii shopping channel
If you haven't connected to the internet yet,then you won't be able to connect to the wii shopping channel.
Jul 19, 2011 | Video Game Consoles & Games
Just bought Lego Harry Potter yrs 1-4 and during game play it goes to a black screen, hums, and won't power off. This only happens at certain spots in the game. We haven't had this happen to any...
Hi there palmer573
What to do when your Wii Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Nintendo if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Wii to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a Wii Repair Guide that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
WiiRestore
Feel Free to leave me a comment if you need further assistance.
May 29, 2011 | Nintendo Wii Console
We use the wii twice a week for about 30 minutes. today the power will not come on.. tried unplug and repluging it in. tried what i could think of.. any help out there.. we take good care of it no abuse...
There are series of problem in Nintendo wii which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the Nintendo repair guide that will help you a lot...
Click here to download Ninento wii repair guide
Jan 05, 2011 | Nintendo Wii Console
The green indicator does not light up.
Try to put it in a cooler room, or set it so that the aerator isnt blocked, and blow off some dust if its on the aerator and on the Wii itself. Hope its solved now!
Oct 09, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
165 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
