Question about Lexmark X2580 Wireless All-in-One InkJet Printer
Cannot change cartridges
When i lift the top cover of my x2580 the cartridges dont move to the middle so i can change them they stay hidden on hte right hand side of the printer
    Problem Solver:
  • 12 Answers
Yau have may change logic card & cartrige bar.
con No.9981903817
raipur
Posted on May 23, 2009
Okay i understand the problem take out the catridges manually or ur button just below the cover its not working properly
How do I get to the ink cartridge to change itin a canon MX 300
You must have power applied to the unit when you change ink cartridges. The cartridge holder should move to the left side of the carriage when you lift the cover to gain access to the ink cartridges.
Dec 21, 2014 | Canon Office Equipment & Supplies
How do I change the printe ink cartridge?
Hi There!
Here's what you can do to replace the cartridge
Just open the top cover together with the scanner cover. When the cartridge carrier move in the middle of the printer, it's the time you can replace the catridge, then lift up the top cover for the cartridge carrier & then the cartridges.
In replacing the cartridges, you just have to push the cartridge down the carrier, you will hear a snapping sound then return the top cover for the carrier and the scanner bed.
Hope this helps!
Vikroks
Mar 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon Printer MX320 re changing the 2 cartridges. I do not know how to open the housing of the 2 cartridges in order to remove and install.
There were two covers that needs to be lifted up to expose the cartridges.
first top cover is the Top Lid Cover (The one with the ADF - it is where documents will be scanned)
2nd cover is the flatbed scanner glass - it is where documents is xerox or copied)
Hold both of these cover altogether and lift this up slowly with some force.
The cartridge carrier will position itself in the middle once the covers was completely lifted up.
Pull up the lock for the cartridge carrier to remove the cartridges.
Hope this helps!
Thanks you for using Fixya
Dec 27, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Where is my ink cartage located om Lexmark 600 my ink is low how to replace cartage
Hi friend if look at the front of the machine below the gap where you lift up the platen cover for making copies there is another gap where you can lift up the top cover make certain the machine is on when you lift it up as the ink cartridges will move from the home position on the left to the replacement position in the middle you will see the grey colour latches this will have to be lifted up so as to removed the ink cartridge black or colour. If you still struggle you can also refer to the printer manual in the printer driver you start-printers-select your your printer and right click - go to properties- select maintenance- and use the step by step instructions to replace the ink cartridges good luck.
Dec 17, 2010 | Lexmark x2580 AllInOne InkJet Printer
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i change print cartridge?
Plug in your printer, turn it on, then lift cover from front, not just scanner cover, reach lower. Carriage will move back and forth a few times before settling in middle of printer. Pull forward on both levers to release covers over print cartridges. Lift up on cartridge on end closest to you and then pull toward you and up to remove cartridges.Remove tape from new cartridges and install as per instructions on box new cartridges came in or just reverse removal instructions.
Feb 04, 2010 | Lexmark X3650 Printer
Where is the catridge of pixma mp 240
easy one.. open the front of the printer, where the paper comes out. Place your thumb under the lip of the printer just under the name Canon and lift. The top of the printer will lift up and lock into place when you lift it high enough. Do this with the printer turned on and the cartridges will slide out from the right into the middle for easier replacement. If you do this and the printer is turned off, the cartridges are hidden from view as they are parked on the rest stand underneath the front panel buttons. Press the grey cartridge release towards the front of the printer and the cartridge enclosure will open, remove the cartridge, refit the new one (or the old one), close the enclosure cover and then drop the top cover by pushing the support leg towards the back of the printer as you lower the top. Then go into control panel, printers and scanners and right click on the printer icon. Select properties, then select the maintainence tab. click on the printer alignment and follow the procedure.. Done..
Oct 31, 2009 | Canon PIXMA MP240 All-In-One InkJet...
How do i change the black ink cartridge on a lexmark x2580 printer
With printer on and connected to computer do the following:
Open top cover.
Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
Wait for ink carriage for taking position in the middle of the printer rail.
Open cartridge top cover.
Pull cartridge toward yourself and snap it out.
Do the same in reverse order to fit new cartridge.
Remember to remove cello tape strip from new cartridge nozzle.
Do alignment procedure after replacement.
Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
How to change ink cartridge in canon mp390
With the machine powered on. Just lift up on the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
Nov 11, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Lexmark X2580 Wireless All-in-One InkJet Printer Logo
83 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
