Switch cables cannot remember were reset/led/spkr wires go for msi3536 ver 2 motherboard Dog ate notes Rgds Fitzy
  • 2 more comments
  • j_fitspatric May 23, 2009
    MSI 3536 VER 2
    Thanks
  • j_fitspatric May 24, 2009
    Thanks,Your solution fixed my problem.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    I found this page.
    Look at the bottom of the page and let me know if your pin configuration looks like either of the two that they show on that page.
  • Ben Wabnick
    whats the exact model of the motherboard?
  • 2,404 Answers
Your welcome Fitzy. Execllent, glad the pinouts that I had you look at solved the problem.
http://www.eprom.com/home/faq/motherboard.htm
Please rate me when you get the chance, I would appreciate it.
Ben
Posted on May 24, 2009
Where connect LED,RESET etc wires are attached
Please refer to the following list of the PANEL1 pin assignments.
Pin Signal Pin Signal
1 HD_LED_P(+) 2 FP PWR/SLP(+)
3 HD_LED_N(-) 4 FP PWR/SLP(-)
5 RESET_SW_N(-) 6 POWER_SW_P(+)
7 RESET_SW_P(+) 8 POWER_SW_N(-)
9 RSVD_DNU 10 KEY
1 SPKR 2 NC
3 GND 4 +5V
AUDIO2
USB3
SPKR1
These are all contained in the users manual. If you don't have one go to Mercury website and download it.
Mar 28, 2014 | Mercury Computers & Internet
Putting wires back on motherboard
Which type of wire's are they? If you are talking about mobo onboard speaker and front led cables. It should be written on motherboard itself. You need to take it to bright light and try to find out. If it is speaker cables it should be in spkr word. If iti s front LED then it should be colour coding on motherboard. Good luck with that.
Jul 16, 2012 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Proper installation of tower wires
According to Gateway Support, the Gateway 505GR desktop computer uses an Intel (Ausberg) 915G motherboard,
http://support.gateway.com/s/PC/R/3724/3724iv.shtml
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWAUGSBURG
Scroll down to the photo with the sections marked in red.
In the top link, looking at the motherboard with the computer case open, the USB and Firewire (1394a) cables, can be seen attached to the motherboard near the letters D, E, and F.
In F that red cable is a SATA cable. One end attaches to the back of the SATA harddrive, (The angled end), and the other end of the SATA cable attaches to one of those SATA headers on the motherboard.
(SATA header = SATA connector on motherboard)
Preferred SATA header for the Harddrive is SATA 1.
DOESN'T matter though. That's the beauty of SATA. You can plug the SATA data cable into ANY SATA header on the motherboard, and BIOS will find the harddrive.
In the second link, looking at the motherboard photo shown, and comparing it to the view of the motherboard as mounted in the computer case, the Front Panel header is at the very Bottom Right.
Two rows of pins in a White rectangular shaped header,
(S points to Front Panel header)
[ The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel wires go to, is the Front Panel header ]
A) Top row has Even numbered pins
B) Bottom row has Odd numbered pins.
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
1) Power LED = Power On LED light
2) Hard Drive Activity LED = LED light that flashes (Usually red in color) when your harddrive is active. Being used.
3) Reset switch = Reset Button. The Reset switch is behind the Reset button. (IF the computer uses a Reset switch)
4) Power Switch = Power On switch
5) Forget about Pin 9. That's for 5 Volts DC - Out. Used by factory.
Which wires coming out of the Front Panel, are the Power On wires, Harddrive LED light wires, Power On switch wires, etc.?
Remove the Front Panel, and trace where the wires end.
IF, the wires already installed coming from the motherboard to the Front Panel, are Too short, you should make notes before you remove them from the motherboard.
Note what color pair of twisted wires, went to where, in the Front Panel.
Compare to the chart of the Front Panel header given above.
(IF any wires are still connected to the Front Panel header on the motherboard)
Once the Front Panel is removed, it's usually pretty easy to trace the two wires up to the Power On switch.
Same for the Power On LED light.
Again, same for the HarDDrive activity LED light.
The SATA harddrive requires a DATA cable, and a SATA power cable.
The connector for a Data cable has 7 contact pins. It is the shorter connector.
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The connector can be at a 90 degree angle as shown, or a straight connector.
IF the data cable has an angled connector, it plugs into the Harddrive.
Straight connector goes to the motherboard.
The connector for a SATA power cable has 15 contact pins. It is the longer connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L shape of the connectors for the SATA data cable, and SATA power cable.
Also;
This is a 4-pin standard Peripheral power cable. Commonly misnomered as a 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, the SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Using both power cables will burn up the harddrive.
May not happen immediately in some cases, but WILL eventually happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2011 | Gateway 505GR PC Desktop
Intel motherboard how to find power switch,led,reset,hdd switch,led
It is silkscreened on the moterboard at the bank of pins for the switches and lights. it is usuall abreviated as PWR SW, RST SW, HD LED, SPKR, PWR LED, ...If it is not silkscreened then look at the manual on the manufactures website. they will have a photo of the MB with it illistrated. go to
http://www.retrevo.com/support/MSI-K8T-Neo-FSR-manual/id/8353ci976/t/2/
Apr 22, 2010 | MSI K8T Neo-FSR Motherboard
Please exsplain in what sequence the wires are conected to the motherboard for the front display and operating switch
An Installation Manual for you model motherboard is available at the manufacturers website. MSI will have a picture of the pin designations for SPKR, HD LED, PWR LED, RESET, etc. They all vary from year to year and board to board though. Best of luck.
Jul 05, 2009 | MSI Computers & Internet
I can not remember where wires go
all the configuration should be printed on yur motherboard....maybe.....?
Mar 08, 2009 | EliteGroup P4VMM2 Motherboard
Compaq 252608-001 motherboard
hello sosumo,
see carefully on the board there might be some sign like:
  • HDD-LED
  • PWR SWTCH
  • SPKR
  • RSET
  • PWR LED
These are the points on your board where you have to connect frontpanel connections.
For more details goto HP website and search manual for your product using your board's model no.
Thanks
Iqbal
Apr 21, 2008 | Compaq (253219-002) Motherboard
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
