Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
Millivolt pool heater will not ignite
I have a teldyne Laars Lite pool heater natural gas, Miilivolt system. The pilot is lit but the burners will not ignite. I turned it on yesterday and everything was fine. This morning it's not. Is there a way to bypass all of the controls to isolate the problem area?
    Scholar:
  • 112 Answers
Most heaters do not require power for the pilot to remain lit. Is there power at he unit? If it worked yesterday and not today has anyone turned it off at the circuit breaker? If you have power turn the gas valve off for 10 minuets and then relight to see if it needed a reset.
Posted on Aug 31, 2009
Where is a flame sensor located on a laars lg millivolt pool heater
first of all millivolt heaters dont have an actual flame sensor. flame rods are located in the electronic ignition models. The only "flame sensor" millivolt units have are the pilot generator or thermal pile. it also works as a safety, no pilot flame = no dc current, heater wont run
Nov 04, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot is lit, but burner will not come on. I jumped TH/PP to TH then burner comes on. Pilot generator = 350mV.
More than likely the tempature control is defective, since you effectively bypassed that connection. I found a manual for your unit which shows different types of ignition. I'm not even sure if the millivolt system is covered in this manual. Here's the sight
http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/jandy-lite2manual.pdf
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
LARS LITE #LLG175N BURNER WON'T STAY LIT.
Make sure your pool filter is clean. Low water flow through the heater will be detected by water pressure switch
Jun 19, 2009 | Teledyne Laars Teledyne_ Laars Lite2...
Laars lite 2 pool heater burners will not ignite
millivolt readings are independent of pump and filter.just make sure heater is in off position for accurate read
Jun 17, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
383 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
