Question about Innovage Touch-Panel Phone 1507102
Hands free voice activated on touch-panel/caller ID phone
Hi
The hands free voice activated after ending conversation on extension phone even though the hands free button had not been pressed to hands free,the message stated the numbers 334314 and the flashing word new appeared in the display,this seems a very strange thing to happen have do you any suggestions as to why it occured.
  • 5 more comments
  • jpmcmahon May 23, 2009
    Yes i have reset to default settings,my question is to why this occured when the numbers where read out they also appeared on the display as when dialing a particular number.
    Do you reconise these numbers and if so what are they.
    What do you think triggered this fualt
    Is the problem associated to the extension phone,i`ts never happend before
    What kind of signal could cause this
    Yes the extension may be not compatible,i`ts not a touch phone
    Yes thank you this solution has been very helpful
    Brigadier General:
  • 3,614 Answers
HI there,
Try to reset the unit first. this may restore the phone settings into default factory settings. it is better that you have the manual with you.
Let me know for any further clarifications.
Posted on May 23, 2009
  • 4 more comments
  • micromaster
    micromaster May 23, 2009
    this can be happening on base system has been malfunction. the unit may need to be reset to clear the error on registering to base station.
  • micromaster
    well I'm not so familiar with that number, but I think it was a Register code that's default on the base.
  • micromaster
    Some sequence of buttons will create a radio signal from base (have
    handset off base) then another sequence of buttons on handset will
    accept radio signal. the error sometimes happen because of this base error,
  • micromaster
    the base & the extension needs to be compatible to each other. if your extension phone is different on the phone model of your base, this error will eventually arise
  • micromaster
    it was a radio signal, all phones transmit a radio signal.
  • micromaster
    This could be the problem coming from..
    Hope everything here was clear for you.
Phone Display
Panasonic KX T7633 user manual pdf
the link above is the manual
The Panasonic KX-T7633 is a telephone that will satisfy your demand for a user friendly operation. You can enjoy the hands free conversations offered by the speakerphone facility that the Panasonic KX-T7633 features. The 2.5 mm headset jack that you will find in this Panasonic KX-T7633 phone will enable you a hands free usage for paperwork or PC. It has a 3 line LCd that gives you a readable and clear display. It is available in charcoal and white color. This phone gives you an opportunity to choose the right color that will go along with the d?cor in your home or office. This device looks professionally because of the executive design. The Panasonic KX-T7633 has 24 programmable keys with dual color LED. It also has a 3 line caller ID LCD with back light. You will love the headset jack. It supports caller ID. The Panasonic KX-T7633 has a speakerphone, Intercom, automatic redial and an LCD display. There is a chance for 8 way conference call. It also features a digital XDP (eXtra Device Port) jack. I warmly recommend this phone for your home or office. You will be extremely satisfied. Panasonic phone models are very durable and you can use it for years to come. It will serve well to your every wish. Before using the Panasonic KX-T7633, it is recommended to read the Panasonic KX-T7633 user manual. If you have lost yourmanual, you can always download one here, free of charge: DOWNLOAD PANASONIC KX-T7633 USER MANUAL PDF
Jan 07, 2014 | Panasonic KX-T7633 Corded Phone
I have a Shift 3 lcd touch panel phone with 12 digit calculator.I cannot find the manual for this phone.I can receive calls but cannot call out.A manual would be helpful Thanks
  • Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
  • 2
    Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
  • 3
    Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
  • 4
    Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
  • 5
    Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
  • 6
    Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
  • Read more: Innovage LCD Touch Panel Phone Instructions ' eHow.com http://www.ehow.com/how_7256783_innovage-touch-panel-phone-instructions.html#ixzz1eMIaaXLV
    Sep 23, 2011 | Innovage Speaker/Caller ID* LCD Touch...
    Does the lg vx4650 have blue tooth capability for hands free
    Looking at the spec sheet for it www.lgmobilephones.com it does not have bluetooth, but does have voice activation.
    Jan 24, 2009 | LG VX4650 Cellular Phone
    Speaker volume
    hi fshmol, press the HANDS FREE button, press delete to select LOUNDNESS (1-4), then press HANDS FREE to confirm, then DELETE to exit to main view.
    tammy
    May 16, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    Need manual
    Speaker part of phone works ok, can hear in coming voice on
    hand set but caller can not hear me .
    Apr 27, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    Volume
    hi pkeyes40, my phone is a differenet model number, but on my phone you raise the volume by hitting the hands free button, then press the delete button several times to adjust the volume ( 1-4), then press the hands free button to confirm. then hit delete to exit. hope it works the same for your phone. good luck. and if you would like me email you with the manual i have for my phone, an innovage lcd phone/caller id 1507102, it might give you some pointers. my email address is all8upinwv@yahoo.com
    email me and i reply with the manual. hope i helped ya out. good luck.
    tammy
    Mar 27, 2008 | Innovage Touch-panel Phone 1502084
    Volume control
    Dear lowis
    Check weather it requires an external power, if it requires then u need to supply it, else if it doesnt require an external power then it is the settings at the subscriber end, which we can not do anything unless we request or complain them. And it is not the fault with the instrument. But note that the instrument mechanism could be designed with a low amplification which means it has poor circuit.
    Feb 08, 2008 | Innovage 69420210126 Phone
    Telephone
    FOUND A MANUAL FOR TOUCH-PANEL / CALLER ID* LCD TOUCH PANEL PHONE WITH 12 DIGIT CALCULATOR...SAYS TO TURN UP THE VOLUME PRESS "HANDS FREE" BUTTON, AND THEN PRESS DELETE TO SELECT "LOUDNESS" LEVEL 1-4,PRESS"HANDS FREE" TO CONFIRM SETTING. PRESS DELETE TO EXIT.
    HOPE THAT HELPS.
    Jan 13, 2008 | Innovage Touch-Panel Phone 1507102
    Voice sound has gone on phone (but ringtones and all other sound working).
    there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
    Jul 02, 2007 | Panasonic G50 Cellular Phone
    Lands Phones Logo
    181 people viewed this question
    Top Innovage Lands Phones Experts
    wiccan8thhouse
    wiccan8thhouse
    spiritsoul
    Level 1 Expert
    Computer Repairing
    Computer Repairing
    Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
