Question about Car Audio & Video
How to change radio on Almera X reg? Does it take a lot of force to remove original fascia panel?
Did a bit of googling and found this site which showed everything in perfect detail.
http://www.fitaudio.com/?View=entry&EntryID=58
Problem solved! Needed a new fascia panel [which I'd had for a while] and wiring adapters for the new radio/cd but these were easy to get from eBay and Halfords.
In retrospect it would have been less hassle just to have got it fitted professionally.
Wife is all smiles now that she can throw her pile of cassettes away.
Posted on May 25, 2009
Remove back bumper from 2004 jeep grand cherokee
  • Raise and support vehicle.
  • Remove wheels.
  • Remove plastic push pins attaching fascia to fuel tank skid plate.
  • Remove plastic rivets attaching fascia to wheel liner.
  • Remove nuts attaching upper edge of fascia to quarter panel and wheel liner
  • Remove plastic push pins attaching fascia to liftgate opening
  • Remove screws attaching fascia to liftgate opening.
  • Remove D pillar trim and scuff plate outboard screws.
  • Remove the rearward tie down screws and the aperture trim panel.
  • Carefully peel back the rubber body sealer patch to access the retainer clips.
  • Release the forward and rearward retainer clips on both sides of the fascia.
  • Grasp forward edges of fascia and pull outward to disengage retainers attaching fascia to quarter panel
  • Separate fascia from vehicle
  • Jul 06, 2017 | Jeep Cars & Trucks
    How do I remove the radio on my almera Nissan car?
    which year
    looks like all the radios need some slid down each side of the radio
    that releases clips to extract the factory radio
    Nissan Almera radio fit
    Sep 09, 2016 | Nissan Almera Cars & Trucks
    Trying to replace a radio in an Nissan Almera n16 (2003), I Is it possible to replace this radio, or because the dash radio/Air-con is all the one?
    Look at the bezel around the radio. It just pops off. If it goes up around the instrument panel, look for screws around there. Under the bezel, there will be screws to remove.
    Sep 07, 2015 | Nissan Cars & Trucks
    Just bought nissan almera 53 reg and need radio code, don't have manual
    The radio SERIAL NUMBER is required for a code
    First remove the radio from the dashboard.
    Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
    This information can then be used to see if a code can be calculated
    Jun 21, 2011 | Car Audio & Video
    Where is the flasher on a 1994 toyota previa
    The flasher is bolted to the firewall behind the right side of the instrument panel and you can't get to it from underneath the instrument panel. You will have to remove the center console fascia to get to the instrument cover screws and remove the instrument cover. Then you can get to the instrument holding screws and move the instrument panel out of the way. Either a service manual or AutoZone.com will have this information and pictures. Replace the flasher with a genuine Toyota flasher relay. The aftermarket relays might look like they fit but I have found out they don't work properly. The flasher is bolted to the firewall with a 13mm bolt. Take out the bolt and replace the flasher.
    Jul 15, 2009 | 1997 Toyota Previa
    Cd palyer won't eject.
    nissan comes with a clarion radio that had eject problems. you are probably better off removing it and replacing it with and aftermarket radio.
    May 31, 2009 | Car Audio & Video
    How to change lighbulbs behind the panel board of 1998 Toyota Corolla?
    Using a short phillips screwdriver, remove the 3 screws that holds the fascia over the plastic inst panel lens. Pull this fascia towards you, and remove it from the dash. With the fascia out of the way, you will see 4 screws holding the instrument cluster to the instrument panel. Remove the 4 screws. Pull the instrument pod towards you, and, working behind the pod, disengage all of the wire connectors behind the pod. When all of the wire connectors are removed, take the pod from the dash, and look at the back side; the bulbs are accessible there. The bulbs are not special; hope this helps, and THANK YOU for choosing FixYA!
    Oct 21, 2008 | 1998 Toyota Corolla
    Car Audio & Video Logo
    617 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
