Question about Microwave Ovens
Jenn-Air abovestove microwave door issue
The door on my microwave will sometimes not close correctly. As a result the light inside stays on along with the power. I have to close the door additional times to get it in the right alignment. Any suggestions?
  • 323 Answers
There should be two metal curved hinges the door rides on. When these get out of alignment, you can loosen the screws/bolts on them and adjust the door, then tighten them again. Have someone hold the door in the desired position while you tighten them.
Also, it is possible, if the doors is shutting smoothly, that you have a faulty light switch that could have food/junk on it, and either not push in or make contact properly. Some of the older styles had a ring screw around the base so that you could remove and replace the switch. You can also adjust the switch with that too, by bringing it out a bit more then tightening the ring screw.
Sirwriter
Sirwriter
Posted on May 23, 2009
Maytag microwave model mmv1153baw light won't shut off and won't start
Either the latch in door (spring related) is not in the correct location or you have a door switch issue and its not expensive to fix if you husband is handy. Part number you can use is 28QBP0495 or the factory one 3405-001034 (more expensive). This issue is common and these switches are located inside the control panel on the left side, the switch you seek is the lowest one in the bracket of three. Good Luck and I hope this helps.
Apr 20, 2014 | Maytag Microwave Ovens
Microwave makes noise after door is opened jenn air model jmv9169ba
Microwave ovens emit powerful radio waves and in general for safety reason should only be used when in perfect working order. It usually costs more to repair an older microwave oven than to simply replace it.
Suggest buy a new one.
Mar 02, 2018 | Jenn-Air JMV9169BAS Convection Microwave...
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Dec 09, 2013 | Jenn-Air JMC8130DD Microwave Oven
Hello my JENN AIR Jenn Air JMV8208BAS Microwave won't turn off properly. When it comes to the end of the cooking time it beeps and the vent at the top closes but it keeps making a noise and it is still...
I would first suggest checking the bottom door switch and its mount.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
The full service / installation manual is here.
If it's not a switch issue, you may have a sticking relay on your control board, which can be economically repaired. Details are here.
Oct 15, 2013 | Jenn-Air JMV8208A Microwave Oven
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
Microwave exhaust door stuck in open and close cycle.
Depending on age You might need a new one. A repairman might be able to fix it.
May 24, 2009 | Jenn-Air JMV8166BAS Microwave Oven
Door does not stay fully closed
This could be due to a faulty door interlock but in most microwave ovens I have seen the light remains on during the cooking process.
May 18, 2017 | Microwave Ovens
Sharp R-1750 Microwave
the door switches need adjusting. remove casing and adjust door switches
Jan 25, 2009 | Sharp R-1750 Microwave Oven
Timer comes on microwave does not
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
I'm betting they do not, and that you have a defective bottom door switch or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Dec 24, 2008 | Jenn-Air JMC8130DD Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
