Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power light fashes green
Power light flashes green but nothing else happens. will not turn on unless I hold down the power and menu button then the power light turns red, I then hit the power button on the remote and the tv will turn on for about three seconds and then it goes back to flashing green power light.
    Top Expert:
  • Sharp Master
  • 52,376 Answers
Failing power supply
Posted on Feb 19, 2018
SOURCE:
  • 726 Answers
SOURCE: Wont turn on
seems like a power issue.
u should have the power checked out on the tv
Posted on Oct 02, 2008
carmine8507
  • 7 Answers
SOURCE: sharp aquos red flashing light tv won't get picture
if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Posted on Nov 09, 2008
  • 50 Answers
SOURCE: Flashing Green Power Light - No Picture or Sound
try accessing tv through the remote control.
Posted on Jul 30, 2009
  • 148 Answers
SOURCE: Sharp Aquos LC30HV4U stopped working
You are in luck!..The units poowerboard is overheating and since you have it taken apart already this is the fix for you!...Check the popped capacitors in the metal box you find on the back of the actual screen inside the unit...This is a very common problem,m so I've helped many this way and wrote a general post on the how to's of diagnosing and repairing the problem, follow these steps and your tv ill be good as new for less than $5.00 before feb 5 th!! :P...Here it goes (please rate if this works out :D).....................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped anyone (or not) then please rate, thank you!
Posted on Feb 03, 2010
SOURCE: Sharp LC37D44U Power LED was flashing green. TV
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Posted on Apr 08, 2011
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
My Epson Stylus photo 830 flashing lights
Got the alternate red/green flashing light ona photo830. The app shown by Bill Miller sorted the problem and got the printer back on line. Use the 'protection counter' / 'reset counter option'
Thanks Bill :-)
Mar 03, 2012 | Epson Stylus Photo 830 InkJet Printer
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
Our eletric went off today and when it came back on we had a flashing green light. There is no picture and we can not get it to power up. Please Help!
did you unplug the set and let it sit awile then plug it up. when you plug it up the light flash then you push the button then nothing happen. does it turn on with remote. also push and hold menu button on front for 10 seconds. Try these things out first
Dec 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
When i press the power on button the green light fashes
You should press the button for about three seconds. This is to ensure that you don't turn on the camera by accident (f. ex. in your bag or pocket)
Oct 25, 2009 | Hitachi Cameras
Green light comes on but nothing else happens. No
try bringing it into a sony store and asking whats wrong with it
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
I have to get a printout... When I went to my IP2200, I found several pages jammed. I simply pulled them out and rebundled the paper and set them in the feed tray. I then pushed the resume button, which...
Hi. In such situations it is best to reset the printer.
This procedure resets canon iP1200 /iP1600 / iP2200 printers.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Jul 29, 2009 | Canon Office Equipment & Supplies
Printer will not respond
Canon S330 Turn off printer
Press the Power button and the printer should turn off, if not, press the Power button once more.
Jul 22, 2008 | Canon S 330 InkJet Printer
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
8. Your printer should respond as normal..
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
143 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
