Question about Honda Generator Engine Parts Air Filter 17210-ze8-003
Need more amperage from generator.
If you made a pigtail that plugged into both 20amp recepticles on a EU3000 Honda generator would it increase amps ?
No! The two receptacles are already connected together where they take power from the generator. Two are provided so that you can plug in two items, but the total power must not exceed the rating of the generator.
Posted on May 23, 2009
How do I cross reference a discontinued part to see if an upgrade is available
On a honda part, I would check with Honda directly. Their customer relations folks are good to deal with:
Customer Relations
Tel: 770-497-6400
Fax: 678-339-2519
Mon. - Fri. 8:30 - 7:00 EST
I did find that part on EBay for sale. I have to admit, I don't recall seeing that part on a Honda eu3000.
Sep 19, 2014 | Honda 3000 Watt Portable Generator
Generator don't generate electricity,there are no 240v
The EU3000 is a 120v generator so you cannot get 240v from it.
Jan 23, 2014 | Honda Eu3000is Eu3000 Generator Service...
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
20amp or 40amp
Well 20 amps at 120V is only 2400 Watts. So yes each recepticle can handle 20 Amps. For a total of 4800W Continuous. The head room Between that and 5500W is generally for starting motors and inrush currents.
Dec 22, 2009 | Tools & Hardware - Others
My honda eu3000 electric start quit working. I
Hi, You need to check the ignition plug behind to ensure it is still working fine. You will need a spanner for this and unscrew it anticlockwise.
THanks
Dec 09, 2009 | Honda 6370C - Parallel Power Kit For ...
My generator eu3000 will see its third winter in Western Washington and it does not start with the key. My wife needs the generator to run an oxygen machine, so the key start is critical. When I try the...
The EU3000 is a gel-pack (spill-proof) battery. Using a 10mm wrench or socket, remove the four (4) screws that hold the end cover on the machine.
Use a voltage meter and test the battery at rest (no load, not running). You should see 12 or higher volts DC. Record the voltage and then start the unit manually. Turn the ECO throttle "OFF" so the unit revs up to full RPM. You should see 14 or higher volts DC to verify that the charging system is OK.
The conclusion:
If the 12V test shows less than 10VDC, replace battery.
If the 14V test shows less than 12VDC, have a HONDA AUTHORIZED shop diagnose it for you.
Hope this helps.
Dolf-
Oct 11, 2009 | Honda 3000 Watt Portable Generator
My Generator is putting out voltage on both the neutral side and positive side of 110 Volt recepticles. When hooking a meter to both sides (Neutral & Positive) it is showing 184 volts! It burnt up a...
Check the voltage with a meter in all the recepticles with your meter leads in the left and right slots on the plugs. Is that 184 volts AC there? If so, your gen has big problems with the voltage regulator. Let me know what you read. You can check the right slot of each plug to the round ground hole on the plug too, should be 120 volts there.
Jul 01, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Honda Generator Engine Parts Air Filter 17210-ze8-003 Logo
255 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
