Question about Samsung Washing Machines
Hi, we have a Samsung B1045 washing machine and it seems to be some electrical problem with it. Sometimes we cannot even switch it on, the display screen just flashes once when pressing the power button. Sometimes we can switch it on and it is running for around 15 mins then it stops and we have the same electrical problem and it cannot be switched on. We would really appreciate your help. Thank you
I have a Samsung vrt top loader washer it keeps displaying 3e. Sometimes it will not even do it. What could be the problem
Melisa, Check and see if still under warranty and contact Samsung for repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Global Download Center
Samsung Washers
Mar 02, 2016 | Samsung Washing Machines
Hi, my samsung washine machine occasionally displays 3E(call aftersales), but works fine sometimes.it's still brand new, say 3 months. What could the problem be?
The E3 code is indicating a problem with the motor.
You should call for service as soon as possible if the machine in under warranty.
Good luck from Detroit, MI.
Jul 19, 2011 | Samsung Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My samsung washing machine indicates the door is open yet its closed whats wrong
the door switch is broken or a wire has come off take the switch unit out and check its connected then check it to see that its working if you dont know how to take it to a service shop they should test it for free and tell you if it needs to be replaced then you can order one from your nearest samsung auth repairer.
hope this helps
merry christmas
please rember to rate this advice thanks
Dec 07, 2010 | Samsung WF337AA Front Load Washer
Samsung dv4006 dryer heat not working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 24, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Display often shows FL but is not overloaded
FL stands for Flood Lock.
this happens when the unit has not tripped the water level switch in a certain amount of time
check that inlet water valves are turned on.
aftarwards it would most likely be a pressure switch,
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Burning smell (electrical) from my washing machine
possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Oct 03, 2008 | Smeg WD16BA Front Load Washer / Dryer
Washing Machines Logo
176 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
