Question about Sony STR-DE475 Receiver
Amp displaying 'protect' and not responding
Amplifier display flashing with "protect" after hearing a loud noise. Can't seem to do anything with it except switch it on and off.
    President:
  • Sony Master
  • 1,114 Answers
Disconnect all speaker wires from the unit and turn it back on, if it stays on, turn up the volume, if it does not go into protection, you have a speaker problem. If it does go into protection, it's less expensive to replace the unit than to repair. This unit is 9 model years old and was roughly 200-250 new. Any repair will be at least 100-150 and not worth the investment vs. return. If you look at new receivers, take a look at Yamaha RX-V series. Easy to use and very well built. Hope your current receiver is ok though!
If no Protection is displayed, turn off and connect one spkr at a time and test until you find the one that causes a problem, then try another spkr in the place of the one causing the short. if it still shorts, take the good spkr directly to the receiver with a short piece of spkr wire and test in the bad location. if it works then, replace the spkr wire, if it doesn't you've found your problem. Audio output chip. This is a very common problem and is repairable, yet the labor is what cost the most.
Hope this helps.
Posted on May 23, 2009
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Protect error
If your amplifier goes into the protection, there's really something wrong. There are different kind of protections but usually that circuit does see a DC voltage on your speakeroutput.
So it's a protection for your speakers.
regards,
Gerard
Jan 31, 2009 | Audio Players & Recorders
Dls 12v amp
Were you testing it in the vehicle?
Sep 09, 2008 | DLS A4 Car Audio Amplifier
Power On Displays Flashing "Protected"
The audio amplifier IC´s are on short circuit.
Jun 15, 2008 | Sony STR-DE535 Receiver
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Jun 12, 2008 | Sony LBT-XGR6 CD Shelf System
It works a few minites,then stops and displays "Protect".
Your complaint isn't a problem at all. This is a usual characteristic of the relevant amplifier. The protection mode comes on when the main volume/bass/treble or whatever is too loud. Unfotunately, you can not overcome it. But, as they always say: It's a Sony:)
May 01, 2007 | Sony STR-DE545 Receiver
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
Sony STR-DE475 Receiver Logo
333 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
