Question about Samsung Cameras
Have a week old Samsung L100. When turned on lens comes out,camera bips twice and lens returns back in.Camera turns off....
  • 1 more comment
  • bdmark May 23, 2009
    Hi Yes camera stays on when connected to comp. but lens does not come out
  • bdmark May 24, 2009
    No still doing the same thing
    Thanks for trying. I cant reset settings, because as lens wont come out there is no image on screen.
    Just black. Thought it may have been a minor problem, so will ring camera house where it came from.
  • 10,515 Answers
Samsung Cameras have a user adjustable automatic shutoff feature which turns the camera off after a period of inactivity to prevent unnecessary battery drainage.
If your camera turns off too frequently, you can change the shutoff time or turn off the shutoff feature entirely. To change the automatic shutoff settings, follow these steps:
To select the settings; access the Setup option in the Cameras Menu (pictured below).
  1. Turn your camera on.
  2. Press the Menu button.
  3. Press the directional pad left-right until you've highlighted the Setup menu.
  4. Press the directional pad up-down until you've highlighted Power Off.
  5. Press the directional pad left-right to access the Power Off sub menu.
  6. Press the directional pad up-down until you've highlighted the shutoff time you desire, or you've highlighted off.
NOTE: If the battery is charged, the camera should power on and stay on provided there is activity. If the camera continues to power off on it's own, it will require service which you can arrange by calling samsung.
I hope this would help you to fix the issue.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
  1. Press the OK button.
Posted on May 24, 2009
    President:
  • 1,383 Answers
First press power button for 10 seconds .
Then remove battery from it and also remove memory card from it.
Then start camera only with battery.
Also reset alll settigns to factory defaults.
Posted on May 23, 2009
  • kishor
    kishor May 24, 2009
    reset all settings to defaults.
    President:
  • Samsung Master
  • 2,923 Answers
There's a possibility that the auto power off is set accidentally. In order for you to check it, connect the camera to the computer and turn the camera ON. At this stage, the camera should not turn off automatically because it's connected to the PC.
Then check the settings and make sure to turn off the Auto power off. If same problem persist after changing the settings.
Upgrade the software of the camera.
My l100 samsung camera beeps three times when i push the power button and then wont come on? I tried to take the battery out and put it back in but that didnt help. i also took out the memory card but that...
Lens motor stalled.
Checkout the price of a repair at Samsung suppor.
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Feb 07, 2010 | Nikon D100 Digital Camera
Lens stays out- "Bip Bip" when i turn it on but no other reaction
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 21, 2010 | Samsung HZ10W / WB500 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
I have a samsung L100 camera, my lens got stuck and the camera would not turn on, I pushed the lens in while turning the power button on, the lens came out and the camera is now functioning, only the...
you've misaligned the lens barrel I think. there's not much you can do to solve this short of a repair, which generally outweighs the price of the camera, due to the insane price of the individual parts. You can try realigning the lens barrel by doing what you did the first time.
Apr 25, 2009 | Samsung L100 Digital Camera
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Mar 30, 2009 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Cameras Logo
107 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
