Question about Kenmore 22422 Top Load Washer
Washer wont work
We overloaded our washer and now it wont do anything. Is there something that could be clogged, or is there a reset button
  • NorseXNW
    NorseXNW May 11, 2010
    When you say it won't do anything does it even make any noise?
    Genius:
  • 1,122 Answers
I would check the lid switch first,then tip the washer back and look behind the motor and see if the motor coupler is broken,let me knoe what you find-mike
Posted on May 24, 2009
Why doesn't my washer drain?
Sounds like your pump is out.
Jul 13, 2014 | GE GTWN5050MWS Washer
Built in washer drier wont start
What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
Jan 19, 2012 | Neff Washing Machines
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Apr 13, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Maytag top load washer - model MAVT546EWW purchased from Lowes. The entire led lights blink twice, then the "regular" wash light is lit. This repeats every 20 seconds or so. The washer will only...
This sounds like the electeronic is faulty. Do this. Turn off the machine and unplug it from the power outlet for 5 minutes. Then plug it in and select a cycle. Make sure the water is on and try the spin only cycle first. if it wont spin only then there is a problem in the controller or the motor circuit. Thsi could be something simple like the unbalance switch or something worse like the motor or controller. ensuder the bowl is central. Pull the bowl to the centre. if rthe button you refer to is an overload button then the motor is faulty. A motor overload button measures the motor current in the neutral leg and if it is too great then it pops and stops the appliance.
Aug 01, 2010 | Maytag MAV7580E Top Load Washer
My duet washer wont work it is lit at control locked whats this mean
A sensor inside has probably detected a problem. Usually it has something to do like too long to drain(something in pump) or suds detect (wrong/too much detergent) unbalance/overload), Motor sensor error and stuff like that. I have a manual HERE
Jan 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer got overloaded with clothes and now it will not aggitate or drain "whirlpool"
Remove agitator and check the spines if worn replace agitator. remove hoses and water pump and check for anything clogging them. also, check the belt for signs of ware.
Jul 27, 2009 | Whirlpool LCE4332P Top Load Washer
WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Jul 15, 2009 | Kenmore Washing Machines
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
LGWM2277H LE light came on does the motor have a reset button i need to push
Hello momof3611
Welcome,
You said, Your LGWM2277H washer LE light flashes. Troubleshooting guide says overload in motor. Is there a reset on the motor that needs reset or does something else need done. washer was working fine until we put a big load of jeans in to wash. when we checked wash soapy water was in washer and I can't get it to rinse. drum is not turning.
If you overload, with to much clothes the weight will trigger this error your having in most washer.
Take some clothes out.
Then try this:
Unplug the washer for 5 minutes, or if you can't reach the plug, turn the breaker off for 5 minutes and then the system should reset itself!
Let me know.I'm looking right now for any reset code in the repair manual too!
Huuum
Please remember to leave a rating.
Oct 07, 2008 | LG WM2277H Front Load Washer
Kenmore 22422 Top Load Washer Logo
103 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
