Question about Toshiba SD-P1700 Portable DVD Player
I have the Toshiba portable DVD player SD-P1700. It will not play any discs, The discs just spin and get no picture
  • Anonymous May 23, 2009
    no same problem, actually i tried that before to see if it might work
Keep pressing the play button when it is reading the disk
Posted on Jul 31, 2010
I have a insigma portable DVD and it freezes 10 minutes through the movie.
Posted on Dec 18, 2009
SD-P1700SE just laods willnot play
Either the lens is bad or you have a bad DVD.
Apr 30, 2012 | Toshiba SD-P1700 Portable DVD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
My Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Jun 07, 2010 | Televison & Video
Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Feb 06, 2010 | Toshiba SD-P1900 Portable DVD Player
My toshiba portable dvd player (sd-p1900) won't play discs. We have two, and the other one works, so it's not the disc. When you put a disc in, it doesn't spin, and it says that there is no disc.
i had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Jul 14, 2009 | Toshiba SD-P1900 Portable DVD Player
Not playing DVD's
have you asked for profesinl help or take it apart to fix the problem
Dec 18, 2007 | Toshiba SD-P1400 Portable DVD Player
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Toshiba SD-P1700 Portable DVD Player Logo
732 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
