Question about Bosch Logixx KDR40423 Refrigerator
Small puddle of water on floor in front of fridge
I have recently been finding a small puddle of water in front of my fridge door but don't know where it is coming from. Model is Bosch Logixx
  • NorseXNW
    NorseXNW May 11, 2010
    Water tray from the defroster? Has it suddenly become more humid and warm in your area?
  • Dee S Jul 04, 2013
    I had this problem too and ignored it for years ( i.e just mopped it)! However the fix is simple : the leak is usually caused by a blockage in the drainage hole situated at the back of the fridge. This hole can become blocked by ice and mould over time. Just remove the drawers to access the drainage hole and remove any excess water, ice and mould with a cloth and a cotton bud. Do not use bleach ( mild soap or sanitizer is sufficient) and don't use anything other than a cotton bud to clear the hole as you will probably damage the fridge.
  • 20 Answers
There is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
Posted on May 23, 2009
    New Friend:
Posted on Jul 04, 2013
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
I find puddles of water in front of bowl
If you're finding puddles of water in front of the bowl ON THE FLOOR, then most likely your wax seal is leaking between the floor and the drain piping. You will have to disconnect toilet, remove water from toilet, remove toilet from floor. There is one other possibility, but not likely If it is just a small amout of water, it could be condensation. If your water source is cold (like well water in summer time) and it is hot and humid in your house sometimes toilet tanks sweat.
Aug 17, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Puddle in front of TFX24CRS
If there is ice on the floor of the freezer, you have a blocked defrost drain. If no ice there, you are getting water from the water / ice dispenser, possibly down the back side of the door panel.
Seal the seams around the water catching recess at your dispenser with a bit of clear silicone. (corners and along the front edge seam with the front door panel.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Open Questions:
See all Bosch Logixx KDR40423 Refrigerator Questions
Bosch Logixx KDR40423 Refrigerator Logo
1,821 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
