Question about Acer Aspire 3000 Notebook
The socket is loose so the ac adapter doesnt make connection so tryint to get base off but its not poppin off and i've came across all the screws.
Taking apart the laptop to access the socket for the AC adapter.
  • 75 Answers
It is not available in the market so you need to contact any acer service cernter for replacing the power adapter socket..
Posted on May 23, 2009
I have a vacuum cleaner which I use in my car by connecting it in the 12 volts lighter socket. In wish I could use it for my Music system at home, is there any possibility that I can use it by some so
You should be able to go to an electronic store and buy a converter from 220 to 12 volt D C. If there is a truck stop near you they will have them.
Nov 27, 2014 | Cars & Trucks
My wireless does not work where can I find someone to work on it.
Wireless phones usually don't give problems unless the base and or the handset has fallen several times. First you need to determine if the base is receiving power from the AC adapter. Is the power light on? Is the display lit? If not. then most likely the thin cord that runs from the AC adapter to the jack is broken. You can test it simply by holding the cord just about an inch from the jack and bend the cord slowly at 90 degrees in one direction, then in the opposite direction. Repeat at the AC adapter side. You may need to hold the adapter against the socket to prevent it from working loose. If the light on the base flickers momentarily then the you need a new AC adapter. You can also check very carefully along the length of the cord to see if there is physical damage. A store like Radio Shack should be able to assist you with getting a new adapter, but you need to carry the base with you. If there is no response from the base then you can try a computer repair store. Most times, technicians who do repairs on computers know of technicians who do repairs on other electronic devices or appliances in your area. I do hope you get through.
Sep 05, 2014 | Lands Phones
I replaced the ac adapter on the motherboard of the Gateway NV5207u and now when I try to power it on, won't power on. battery light red
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Mar 30, 2013 | Gateway NV5207u Notebook
My gateway nv79c54u laptop ac plug doesnt charge just blinks orange
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 12, 2012 | Acer Gateway NV79C54u 17.3-Inch Laptop...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
When turned on the screen stays black.
What about the other things? Does the cooling fan work? What are the conditions of the indicators? Does the DVD drive open? Anyhow try this: Remove the AC adapter and battery. Then hold on the power button for up to one minute. Then connect the AC adapter only and try to switch on as usual. If it does't fix the problem, then remove the RAM module. It is located under a cover which has two screws on it. If you remove the screws, you can see it. Pull slightly apart the two clamps holding the RAM. Now it will lift up a little aoutomatically. Carefully pull it outwards. Then reinsert it holding it by 45 degree angle from the base. Push it back to the socket. Keep the notch on the module is aligned with the base.
Feb 24, 2010 | HP Pavilion dv1000 Notebook
Dell precision m50 will not boot power light just flashes when I push the power on button. I have reseated all of the connection in the laptop. I have tried different batteries and different power...
remove external peripherals. remove battery. use ac adapter alone. check if ac adapter has sufficient power or check if ac adapter led is solid green or blue. if not then ac adapter might not giving laptop enough power to power up.
if ac adapter led stays on but some problem check the ac adapter - laptop pin socket if loose or damage. if not then replace mobo.
Dec 07, 2009 | Dell Precision M50 Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Help!!!!!!!!!!!!!!
It's probably the power socket on the laptop not the power jack on the AC adapter. You need to open the laptop by removing the casing screws. Then remove the motherboard from the base so a new socket can be soldered on.
Apr 02, 2008 | Sony VAIO PCG-V505EC Notebook
Acer Aspire 3000 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
