When we shut off tv for the day the fan motor continues to run it does not turn off
When we shut off the tv for the day the fan motor continues to run
  • 8,617 Answers
The fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
Posted on May 23, 2009
  • chris doepp
    chris doepp Jan 10, 2014
    No it wasn't helpful. Already know this. It keeps RUNNING.
Fan motor won't turn off even with car off
Fan relay or temp sensor is bad.
Jan 03, 2018 | Cars & Trucks
Hitachi TV Model 43FDX10B
open it up get dust all out clean it well ok then ya use fans around it vented area to keep it cool its getting to hot dust build up
Jan 28, 2008 | Hitachi 43FDX01B TV
Cooling fans continue to run when engine is shut off
This is normal. Cooling fans today are not turned by the fan belt but are run by an electric motor. The fan continues running until the coolant temperature is reduced
Apr 02, 2014 | 2003 Volkswagen New Beetle Convertible
Cooling fan runs even after motor turned off
This is perfectly natural for the fan to continue running when the motor is turned off. I have seen them run for up to 15 minutes depending on how hot the day and the engine are. If it is not cutting off at all then you may have a problem in your heat sensor.
Jun 17, 2010 | 1999 Jeep Cherokee
No cooling, coils frosting up, defrosted with blow dryer several days ago and cooling fine again, but frost is building up rapidly again. I suspect a defrost heater, please confirm and where to order a...
The evaporator (inside) coil can ice up for the following (typical) reasons. Check the ones that you can and hire a professional refrigeration technician if you can't find the problem yourself.
1. Thermostat isn't shutting off. (Does the compressor run continuously? Can you turn the compressor off while it is running by turning the freezer temp control down (but not off)?
2. Internal fan (evaporator fan) is not blowing air. Possible causes: fan blades hitting something; debris blocking air flow; fan motor bad; no power to fan.
3. Low refrigerant (freon) charge. Need a technician for this one.
You can get thermostat or fan motor at a local appliance parts store. Try googling "appliance parts <yourzipcodey>"
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
1999 grand cherokee jeep -coolant fan will not shut off
Hi Jeepers,
The fan will occassionally continue to run for five or ten minutes after the vehicle shuts down. This is normal.
What is not normal is if it keeps running until the battery drains.
Does it just keep running?
If it eventually shuts off, how long does it take?
Did this just start happening?
The two days you mentioned, were they short trips, opposed to the third day?
If you would comment me back with some more details, it would help me help you.
Mike
Jan 12, 2009 | 1999 Jeep Grand Cherokee
Noisey sonykds-r50xbr1
The fans continue to run after these TVs are turned off, so its likely that its one of the fans. The most likely fan is the exhaust fan that is in front of the lamp assy.
michtech
Dec 20, 2008 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
