Question about Dryers
Door catch model CTDoo
Door catch broken cant find right
  • celiabond495 May 23, 2009
    tab broken inside
  • 111 Answers
With most dryers, you should have the ability to reverse the door so it opens the opposite way. Will this work for you, or is the tab broken off of the door?
Posted on May 23, 2009
Servis easi logic 1500
the doors can be dismantled and a new handle fitted. if you go to google. type in the make, model and end it with spares, it should come up with companies that supply parts. in the uk i use espares.
changing it can be fiddly but take pictures as you strip the door down so you get the pin, catch, handle and retaining spring in the right positions
May 01, 2014 | Washing Machines
Hotpoint aquarius ctdoo. the door catch on my dryer is not holding the door shut. do i have to take the outer casing off to get to it to replace it? is it a fairly easy job? thaks for any advice
You should not need to remove tho outer casing, usually the latch is screwed straight to the door, I see if I can find the replacement,
which is your model?
Apr 20, 2008 | Dryers
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
My hotpoint ultima wt761 door catch has broken how can i open the door
If you have a broken door catch you can get the door open by feeding some garden wire around the right hand outside of the door (between the door and the metal casing of the washing machine).
Once you've fed it in round the top right and bottom right curved corners pull the two ends of the wire to the left, so that the wire pulls against the lock mechanism, and the catch should release.
Feb 26, 2011 | Washing Machines
I CANT OPEN MY MICROWAVE
Door catches.
One of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 27, 2011 | Sharp Microwave Ovens
I pushed in the white piece where the door catches and the microwave will not run and the light will not go on
You've broken the door catch. You'll have to take off the outer casing and check whether they assembly has simply come loose or whether it's broken and in need of replacement.
As you haven't given specifics regarding make and model I cannot be any ore specific myself, but it's a very straightforward job and is usually almost identical regardless of make and model.
May 20, 2010 | Microwave Ovens
The dryer door won't stay closed on my 90-series electric. Doesn't matter if the dryer is running or not. Have to keep the door closed by propping a weight bar against it. Any suggestions to get this...
There is a door catch made of plastic that holds the pin thats sort of arrow shaped on the door... The plastic catch is located on the front of the panel and can be easily replaced....Call the local repair shop/man to get the part....very cheap part maybe a couple of dollars at most... You should be able to remove the broken one with just a set of pliers and a screw driver...doesn't matter anyways its already broken right!! the new one will push and snap right in....Good Luck
Apr 20, 2010 | Kenmore Dryers
The door catch on my easi logic 1200 washing machine has broken
The door catch will have to be replaced, depending on model you can buy these from a repair shop for a few pounds.
You will have to open the machine to get to the door catch from inside.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
Remove the power supply as mentioned above, remove the top cover reach down inside and try to open the door, (BE SURE THAT THE DRUM IS TOTALLY EMPTY OR YOU WILL FLOOD THE FLOOR)
I can't advise exactly how to open the door from the inside, beacuse I do not know the make or model No.
If you are successful in getting the door open, the screws to remove the broken catch should be visible just inside the door.
Best of Luck!!
Jul 04, 2009 | Kenmore 4292x Front Load Washer
Dryers Logo
102 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
