Question about LG WM-2277HW Front Load Washer
Washer WM-2277HW and Dryer wont turn on after power outage.
We had a power surge/outage a couple of days ago and the washer and Dryer would not turn on at all.  The breakers were reset and checked for power but the Washer and Dryer would not show signs of life.
I was thinking that there is an internal fuse that can be changed inside the appliance but can't find it.
Please help me with this urgent issue.
  • Anonymous Dec 26, 2007
    Washer doesn't turn on
  • 58 Answers
There is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Posted on Oct 31, 2007
Thanks ....ive tried replugging for the last couple of days n left it for a day...
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at or call LG at 800-243-0000
on Mar 31, 2010 | LG WM-2277HW Front Load Washer
No power for lg wm2277hw
Power supply has failed to the panel board and it can due to failure of the board, failure of the surge filter or the power circuit.
check the panel and if there is short within the board then the panel must be replaced
Jan 16, 2013 | LG WM-2277HW Front Load Washer
My LG Wd1238c front loader machine wont turn on, plugged in but nothing even turns on..
You have a dead control board that will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 28, 2012 | LG WM-2277HW Front Load Washer
After power outage compaq presario SR1123WM desktop wont turn on
Nov 06, 2011 | Computers & Internet
My LG tromm wm2277hw front loader just turned off, can it be a switch, there's power in the outlet, no lights, circuit board is off, no water underneath, dryer is ok plugged in the same outlet,
That could very well be the line voltage suppressor (called a noise filter) that is built into the washer. Take the top off and follow the power cord into the machine. It connects to this component. themobilian_17.png
Feb 06, 2011 | LG WM-2277HW Front Load Washer
LE error on the (WM1812CW) WONT SPIN!
my washer did this 5 minurtes ago, it means the load is unbalences [u]n[e]ven if you have to little or too much ibn it, take everything pout, let it spin through then do load again with les sor more acording to previous.
Dec 29, 2010 | LG WM-2277HW Front Load Washer
My new lg direct drive washer just quit mid cycle, it wont start back up the code indicated power outage, but it comes on just wont run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 04, 2010 | LG DLE2512W Electric Dryer
LG WM-2277HW Front Load Washer. I am trying to remove the big nut
the best way is to have some one hold the drum from the front and turn the nut. it can also be done sometimes by turning the drum in the opposite direction and then pop it with the wrench. not the best way but it works.or you can hold the stator assy with one hand and tap your wrench with a hammer.i hope thia was helpful,would like to here how things worked out.
Jan 22, 2010 | LG WM-2277HW Front Load Washer
Water draining out of the bottom of washer
Dec 09, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
788 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
