Question about Sungale DVD-2026 DVD Player
Wrong disk What does wrong disk means?
  • captchaps May 23, 2009
    I can watch the movie on my computer but not on my dvd. What can I do when I burn the dvd to be able to watch on my Dvd players. Settings problem or what,, Thanks
I looked at everybody's ideas, and none of the ideas seemed to fit my situation. My DVD player has been working fine for one month. I got a new DVD today in the mail. It froze, and then began to display the WRONG DISK message. Then, nothing would play on the player, All of the DVDs that had worked fine before, now would not play. They all said WRONG DISK. I tried reaching under and trying to clean the laser lens, but that did not fix the problem. I am not saying that this will fix your problem, but this is what fixed mine.
1. Place the DVD player on a table
2. Plug in the DVD player.
3.Push the OPEN button so that the DVD platter extends outside of the player (It now looks like it does when it is ready for you to put a DVD in it to play it.)
4. Unplug the DVD player. (Now the power is off, and the platter is still extended.
5. Remove the cover of the DVD player being careful not to damage the extended platter.
NOTE: With the platter extended, looking slightly from the rear, under where the DVD is spun, you will be able to see the Laser lens. It will be covered by the mechanism that spins the DVD. The lens will be connected to a mechanism that that has two rails on either side.
6. Grasp the plastic surrounding of the laser lens area and pull the entire mechanism toward the rear of the DVD player.
CAREFUL: DO NOT YANK THE MECHANISM BACKWARDS as this will break off the laser unit. This mechanism is being moved with the resistance of many gears. PULL SLOWLY AND FIRMLY, and the entire mechanism will move on the rails until the laser unit is clearly visible to you and completely from under the spinning mechanism.
7. Since the lens was clearly visible now, and easily accessable, I carefully and lightly cleaned the lens with a Qtip and alcohol.
8. Replace the cover on the DVD player
9. Place a DVD on the platter.
10. Plug in the DVD player
You will find that you no longer get the WRONG DISK message and your DVDs will now play properly. As I said, just reaching under and cleaning the laser lens did not seem to fix the problem. It was only when I moved the entire laser unit from under the spinning mechanism, and forced the DVD player to realign itself when it powered on, did the DVDs begin to play again.
Posted on May 28, 2009
    Sergeant:
  • 199 Answers
Thats mean disk is not supported to that device.not compatible with DVD player.
Posted on May 23, 2009
  • 73 Answers
It means your player can't read it, maybe it's from another region, bad disk, or unreadable format by your DVD!
How to recover the hard disk in wrong copy source
Step 1:
I'm not quite sure what you mean ? or what you are trying to do ?
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
There are also Data Recovery programs that might be very helpful to recover your important information. Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Apr 03, 2013 | Computers & Internet
My dvd player says wrong disk. What do I do?
it means that the disk you put in is not the right region.then you need to buy yourself a all region DVD.good luck.
Sep 23, 2011 | Coby 7" Diagonal Tablet Style Portable DVD...
Get message verify DMI Pool data...... then it stops
it means that something is wrong with the hard disk. Try reinstalling Windows - if it fails then the hard disk is defective, replace it.
Dec 04, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Disk unreadable
well if that is the issue it only means that there is something wrong with your disc drive and you need to call xbox hardware right a way
Jun 07, 2010 | EA Sports Video Game Consoles & Games
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
Error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Mar 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Its is saying that the operating system not found on my acer aspire 3050 laptop wen loading up. what is wrong?
Generally it means that Windows is not installed on your computer, or you have a floppy disk in its drive that does not contain a start up disk (assuming you have floppy disk drive).
Were you deleting any files during its last use?
Sep 16, 2008 | Acer Computers & Internet
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Dvd reads wrong disc
Since 4 days I've searched 99% of internet to fix 'Wrong Disk' solution for my DVDV822-05 Player, but I could not get any such solution. Some solutions for other players of the same company is to change region codes but I could not find these codes for this particular model. I got this player from some other country which I dont know. It's sayying 'Wrong Disk' to all disks either MP3, audio, VCD, DVD etc. It's my humble request to all e-guys and companies to find some solution for this model.
Jan 02, 2008 | Televison & Video
Wrong disk
There are many chip sets for DVD machines and each has preferences for a range of disk types- most will play straight commercial discs- but things get a bit tricky with the many and various types of 'burned' disks from computers. The strange thing is - it seems the cheaper the player the more versatile they be whilst a Hi grade one can be a tad fussy about what it will and will not do. So what does this mean to you? Check the types of disk you have been playing on it and stick to it- come back with exactly what disks it don't like
Jul 11, 2007 | Protron 7" Portable DVD Player
Sungale DVD-2026 DVD Player Logo
649 people viewed this question
Top Sungale Televison & Video Experts
janman
Chris Baker
Chris Baker
Level 1 Expert
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
