Question about Dishwashers
Hello I have a built in DCS dishwasher - width 24" heigh 35". It started smoking out the front and the repair man said it needs a new control board. Is that possible or should I buy a new one. IT is not a dishdrawer its a full dishwasher. the top rack is also broken. If I need to buy a new one - where from - new jersey area
  • loiswilson May 23, 2009
    You didnt answer my question.  I asked if i could buy a new control board anywhere and a new top rack
  • 75 Answers
Posted on May 23, 2009
What is the installation specifications on this particular model? Dimensions?
Patty,
Most dishwashers need an opening that is a minimum of 24" wide and 34" to 35" in height. Normally, you can adjust legs on the unit to adjust for the height you need, but you have no adjustment for the width. Hope this helps!
Mar 02, 2016 | Whirlpool 24 in. DU800CWD Built-in...
Need reset sequence
o reset the control module AP2802870, you will put the dishwasher into the cancel/drain mode and let it complete the cycle. When you installed the new control remove the jumper from the original front lower right hand # 1 board male port. Starting from the extreme lower rt.corner, there is a 6-terminal connector with a jumper wire looping # 5 and # 6 terminals. (counting from the right to the left). Use this on your new board. Then reset the controls.
Apr 18, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
I have GE Profile dishwasher Model PDW9880 series. It will not drain. We had a repair man come & he said it needed a new control board. Do you think this is true? If so, can I purchase one one my...
Of course you can purchase the part. Module runs around $100. Dishwasher control boards are usually easy to replace, but there's no way I can determine if you're capable of doing it.
Jul 14, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Started smoking out of the power switch.
Greetings,
yes, this switch will go bad from moisture and such..its possible its NLA...I will continue to search and get back with you here.....
Jan 05, 2011 | DCS DW-24-SS Built-in Dishwasher
I have a whirlpool Du810SWRQ0 dishwasher. Whwn we wash the dishes, it is ok until the drying process start. Then it has smoke from inside. So, we can not use heat dry anymore.
smoke from inside the dishwasher or the panel?
if smoke is from inside the dishwasher... firstly check that the element is clean? is there any evidence of melting on your lower basket shelf or cutlery basket? if so the thermostat or rhe heating element control may be faulty and will require repair. If its an old dishwasher, sometimes its just easier to bite the bullet and buy a new one.
Dec 17, 2010 | Whirlpool 24 in. DU810CWD Built-in...
Dirty Dishes Electrolux builtin dishwasher
How long ago did you clean the filters?...are they blocked or maybe damaged letting particles through.A cherry pit should not be able to get to the pump.
Jul 20, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Kenmore dishwasher model 63991 (10yrs old)
If the display works, but the machine doesn't fill, wash, or pump out, the control board is the only component that could cause all these symptoms.
Aug 26, 2007 | Kenmore 24 in. 16259 / 16254 / 16252...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
Owen Barnes
