Question about IBM eServer xSeries? 206m
IBM server dc can't boot due to system32\drivers\pci.sys missing
IBM server(domain controller) type x series 206 m - 8485 IRS is having two 80GB HDDs in RAID0 confign.It is not booting and giving following message.
''Windows could not start because the following file is missing or corrupt : system32DRIVERSpci.sys and you can attempt to repair this file by starting windows setup using the original Setup CD-ROM.Select 'r' at the first screen to start repair.''
Using Windows Setup CD-ROM the message come ''No HDD detected, press F3 to reboot.''
But it is observed that initially RAID0 confign is shown with single logical drive with capacity around 158 GB.
pls suggest remedy
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    are you using windows xp on the server and also what type off hard drive are you using, SATA, IDE, etc?
  • Aaron M May 11, 2010
    Are the hard drives SATA or SCSI?
  • 4 Answers
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
Posted on Jun 01, 2009
Thank you for the last one. know i want to set up mu 3laptops on the windows server 2008 r2 standered and use the server as a domain and the laptops as well like a domain.
first you need to setup the roles in the server, go to the manage server console, ( can be found as a shortcut in the taskbar or under start menu ) then open the console and go to add roles.
1 - add active directory
2 - in the process it will ask you to install the DNS server role ( do it )
3 - after installing the role in the CMD command prompt type DCPROMO
4 - the DC controller installation and setup will beging ( do not do anything during this proccess )
5 - when asked by DC setup to choose what type of domain functionality level do the following
1 - windows 2003 ( this is for compatibility for windows server running 2003 and XP machines )
2 - Windows Server 2008 ( at this point nothing lower than XP can be added to the DC of course domain functionalities will increase - Only other 2008 server domain controller can be added and cluster migration from server 2003 to 2008 is not supported. )
3 - Windows Server 2008 R2 ( at this point only machines running Vista and 7 can be added to domain - windows xp is no longer supported. All the functionalities of the domain controller are available)
keep in mind once you promote the domain controller to a higher level it can't be brouht to a lower level.
once active directory is installed restart you server and the you should be able to add the clients pc or laptos to the DC example
- right click over my computer icon
- click on properties
- computer name
- change the computer from workgroup to domain
- type your FQDN ( fully qualified domain name) example: mynetwork.local or mysite.com
- apply changes and restart
- your computer will be part of the domain next time system boots up.
Mar 01, 2011 | Computers & Internet
Windows won't start
When you put in the XP CD and it boots off the cd, the XP setup files copy across, and at the 1st screen, you should be able to choose Repair. Press r, and this will start the Recovery Console.
When you are in the recovery console, choose your Windows installation (You will see what I mean when you follow the instructions.)
When you are sitting at the command line(C:\>Windows), access your CDROM drive by typing the letter followed by a colon, eg "D:". It may also be E:, F:, or G:.
When you have changed to the CDROM drive, type the following:
cd\ <enter>
cd\i386 <enter>
expand pci.sy_ C:\pci.sys <enter>
C: <enter>
cd\ <enter>
copy pci.sys C:\windows\system32\drivers <enter>
If it asks to replace, confirm.
Then restart the computer.
Regards
Riztech
Jul 17, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
One of the disks in not readable and while booting i get a message of pci.sys file missing or corrupted and i cannot start the system
expand the missing/corrupt file from i386 on your installation media to the system32 directory on the server using the bootable OS CD, select the recovery console option, not the repair OS option.
Dec 21, 2009 | IBM x3400 Server
IBM x-series server(8485-206m)[domain controller] having two 80GB SATA HDDs in RAID0 confign, was having windows server 2003 R2 standard edition installed.Now the problem is server is unable to boot and...
first check ur hard disk connections with the motherboard after thir reinstall windows but before that format the drive in which u r installing ur windows there is no need 2 format other drive
Jul 03, 2009 | Computers & Internet
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
Presario 1700T wont boot- missing "system32\drivers\pci.sys".
you may want to try booting up from xp or recovery disk and select "R" to repair.
Jul 07, 2008 | HP Compaq Presario 1700T Notebook
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
IBM eServer xSeries? 206m Logo
445 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
