How to fix Black Horizontal Line on Samsung Plasma TV (PN60F8500)
It is possible that the buffer board will fix your problem, but try removing, cleaning and reseating the flex cables between the buffers and the panel first. All it takes is a little bit of dirt or oxidation to open a connection and cause a line-out condition. Use a lint free cloth and a little bit of alcohol to clean them. Make sure to fully insert the cables and center them perfectly in the connectors or you will have even more lines. If the original line is still there after cleaning, then try replacing the board. Buy a board from a reputable dealer that will guarantee no problems with the board. If you still have the line even after changing the board, then the plasma panel has failed and the only fix is to replace the panel.
Always let the tv set for an hour unplugged before attempting any repair work. There are dangerously high voltages in plasma tvs that can cause severe shocks or even *****.
