Question about Philips Televison & Video
Philips tv - unable to access auto channel menu without remote
I have a older big 27'' Philips Tv model PC9227 C121 with no remote. I hooked up the cable, but there are missing channels. Suppose to be 78 channels, but channels 8-11,42,44-59,61-78 is missing. I figure the tv needs to do a auto channel program, but when I bring up the on screen menu, I only see CC, timer and exit. How do I access the other menu with all tv features? I don't have the manual also. I pushed the volume + and - buttons together to access menu, but can't go any further to other features. Do I need the regular remote to do this? Or is there is a trick with buttons I missed?
snakehead
  • 1074 Answers
SOURCE: Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
Posted on Mar 26, 2007
  • 298 Answers
A universal remote with all the bells and whistles and
the right working code for your TV, Buttons like
menu, enter,tv.vid,pip, etc
Posted on Nov 20, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Posted on Feb 13, 2008
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Posted on Mar 31, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
I have a 27 inch philips tv serial number 62573703 model #pc0127 c121 i tryed to go to the menu and it only gives me the caption on or off and the sleep timer i need the channel search trying to watch dvds...
Hi if you are using a universal remote control that will be the cause, if not the tv has a problem with the system control IC this IC is responsible all the signal being transmitted to the unit solving this fault must be check and test in actual by a well experienced technician I suggest that you should contact a service technician to do it for you and save you from stress. Or replace the battery of your remote if no changes you really have to contact a tech. good day and best regards.
Sep 12, 2011 | Philips Televison & Video
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
No menu access without remote
the channel selection buttons are supposed to pressed at the same time. the menu page will appear on your screen, use your volume for moving the pointer. entering using one of the volume button. thanks
Dec 28, 2008 | Philips 27PT543S 27" TV
Is My TV ATSC or NTSC?
Yes, you will need a converter box if you are currently getting TV off-the-air with a rooftop or indoor antenna. This TV does not have a digital tuner. You don't need a box if this set is being used on a cable or satellite system (unless your service provider tells you otherwise).
Dec 10, 2008 | Philips TV Tuner Video Capture PCI Card -...
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
If that fails:
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Can't find any info on this model pcw027 c121
IN MENU SET TV TO AUTO PROGRAM BUT MAKE SURE IT IS SET FOR CABLE TV
Jan 17, 2008 | Televison & Video
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Televison & Video
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Aug 21, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
789 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
