SOURCE: Ink system failure
I had exactly the same problem with my HP 8230 and tried all the posted sugestions with negative results till I stumbled on this site site offering an update for a different problem but added " also clears many ink system failure messages " I downloaded and installed the update and the printer burst into life and now works perfectly, which proves mine was a software problem not a hardware one. give it a try you might get lucky.
http://www.birseyindir.net/driver/HP_Photosmart_8230__Print___12760.html
Alan
SOURCE: the ink system has failed
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
