Question about Canon PowerShot S500 IXUS 500 Digital Camera
Quality of pictures poor
The picture is coming hazzy and dim. We have cleaned the lenses and are using fully chrged battery.
  • soralan May 11, 2010
    Can you post a sample somewhere and link to it.
    Also what settings are you using, make sure its on full res etc and theres enough light for your picture.
  • 10,319 Answers
If to card is very old and used quite a lot they seem to produce real bad photos. Try another card first
Posted on May 23, 2009
I have a Canon 40D and have never replaced the original lithium battery as someone told me that rechargeable Li - ion batteries don't have a lifespan. My picture quality isn't what it use to be...
The battery does not affect the picture quality. The recharageable battery may affect the auto focus if the battery is low, recharging the battery should fix this problem. Otherwise the camera needs a service.
May 05, 2012 | Canon Cameras
Poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
Jun 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Samsung dlp HLT5676SX problem
There is a mirror system and lense within, the mirror is much harder to get to... there is a chance when you were changing the bulb your hand smudged the lense... look inside when you inserted the lamp and check the lamp itself...
Nov 13, 2009 | Samsung Televison & Video
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Video quality is poor
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Feb 04, 2009 | Veo Velocity Connect Webcam
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Panasonic - Poor Picture Quality
There can possibly one problem. If you check on tube bords. There is a white plug that plugs into the tube. If you carefuly open that white plug, there is 2 silver contact point, called the spark. clean it with benine., but it must be clean. If you have to use small peace of sand paper ok. But afther that use clear Q-Tex (for Nails) and cover points. Let it dry and set will be ok.
Thanks
Mar 30, 2008 | Televison & Video
Pictures come out weird
choose the picture quality to AUTO or LOW LIGHT setting. And make sure ur lense is clean (clear, no dust)
Aug 11, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Canon PowerShot S500 IXUS 500 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
