Question about Canon PIXMA MX310 All-In-One Printer
Refill cart. not working
I refill the colour cartridge. LCD first read as cart return
Then check ink appears
no printing.
black cartridge is full
pl help
  • 37 Answers
Press stop for 5 sec
Posted on May 23, 2009
    President:
  • Canon Master
  • 990 Answers
Hello sir;If you don;t have precision equipment to refill the cartridge don't do it that only give you trouble go to buy a new cartridge. I know you not satisfy my answer but that's only one answer.
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Just refilled the ink cartridges on my HP Photosmart C4400 All-in-One series with refill inks. It doesn't seem to print full colour, my prints are coming out a muddy blackish purple colour. How can I get...
If you do a lot of printing you may wish to look at an option such as this
http://cgi.ebay.com/Continuous-Ink-supply-system-Hp-74-75-CB335WN-CB337WN_W0QQitemZ370247388012QQcmdZViewItemQQimsxZ20090819?IMSfp=TL090819164007r16027
You can't get the in in the wrong section of the cart (which I suspect has happened).
Please note the link is for information only and I neither know nor have used the seller listed. A google search may well provided a list of sellers for you to choose from.
I have used a continuous ink supply on my Epson (have you noticed they appear less on here for problems?) for 3 1/2 years now and my printing costs are minimal compred to useing either after market refills or refilling myself.
Sep 07, 2009 | HP Photosmart C4480 All-In-One InkJet...
My printer wont print black colour on pics or word docs
Hi, sounds like a dodgy ink cartridge. I would purchase a new black cartridge and fit and try that. Refilling epson cartridges isn't a good idea, if you can't afford originals, but compats instead of refilling them. a good place to buy is www.choicestationery.com I've never had any problems with their carts.
Dec 14, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Refilling lexmark cartridges x2500
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Jan 15, 2008 | Xerox DocuPrint M750 InkJet Printer
Dell All-in-One Printer 964
I tried all the above and it is stll not reading the ink levels.
Dec 22, 2007 | Dell Photo 964 All-In-One InkJet Printer
Lexmark X2550 Cartridge Refilling
I just ordered a Lexmark X5495. The carts that come with it are throw aways (or return them to Lexmark to be remaned.) You can use cart. # 28a, 29a, 34 or 35 to refill, the latter two being the high yield carts. And yes the printer manufacturers are playing a cat and mouse game with us. I normally use Epson because it's easier to circumvent the tricks they employ. I understand Canon is an inexpensive printer to run also. HP and Lexmark are the costliest products to operate. There is a utility for Epson called SSC ver. 4.30 that gets around the safeguards by resetting the cart. chips and a whole lot more. Someone needs to write a utility for HP and Lexmark to replace the standard driver/ink monitors that are designed to siphon off our wallets quicker than they do ink. One more trick I've heard: when the printer is looking for a new cart have a spare cart handy and put it in in the printer. The printer will now think you have ink in the cart.(whether its empty or full) Now trying swapping it out for a refilled cart and see if that works. The point is this: the printer wants to see a new cart serial# ,not the same one that was just being used last.
Oct 29, 2007 | Lexmark X5495 Printer
Just stopped printing black!
Hey Johnny, Your dead right. The purge tube would affect all the colours. If you are using refilled carts, try just changing the cart. Approx 10% of all refilled carts fail - so it is entirely possible you have hit on a bad one. If you are using the good stuff, I would suggest getting the cleaning kit and doing the manual clean to clear any blocked nozzles. What does the nozzle check pattern show? If there are a few lines visible, I would guess cleaning will sort it for you. Let us know how you get on...
Jun 10, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
197 people viewed this question
old marine
old marine
