No power, will not turn on
We connected a Laptop via svga and trid to turn on the TV. TV did not come on. So, we disconnected the svga cable and tried to turn on the TV. no luck. We checked the power outlet and power is there. Any ideas? I have one that is acting the same. It started with the screen going blank and would not turn off unless you unplugged it . Then it might work for a while and you would have to kill the power again. Now it wont do anything . Vizio says it is pretty much a throw away unless I want them to look at it , There has to be an easy fix out there for this ..HELP!!
    Problem Solver:
  • 5 Answers
My 32 inch vizio would not turn on and an HDTV technician came out to fix it because it was only 15 months old and he said it was the power board. He said every vizio he's worked on has been a bad power board.
Posted on Jan 25, 2010
  • 111 Answers
You might be able to locate some capacitors in the power supply section and replace them. I'm not a Vizio expert but caps don't cost much and if you can use a soldering iron, it's worth a try before you decide to do something brash like throw it out.
Posted on May 23, 2009
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
Jan 05, 2014 | Panasonic TH-50PX50U 50 in. Plasma HDTV
I am currently trying to connect a laptop to my TV monitor for watching Hulu and some wmv files. Everything is fine on the laptop and when i connect via an SVGA cable everything is fine for 10-40 minutes...
Tries go into the computer Control panel go to monitor resolution change it lower resolution like 1020 to 800 should solved ur video problems,scrambling video is tv not supporting the current resolutions.
Jan 30, 2011 | RCA MM36100 36" TV
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
I connected my hp laptop to my pioneer plasma via svga cables. When i select my pc input using my tv remote it says "plasma display no input signal". How do I fix this?
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Jan 11, 2010 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Connecting TV via LAN to a laptop as a monitor
You can connect any laptop to any TV with an SVGA port by use of a pair of Baluns. These run about $49 each; you need two. Try MCM.com. They have several models. As long as your LCD has an SVGA or VGA monitor  input the baluns will emable you to send a signal from laptop to display.
May 07, 2009 | Sony LF-X1 12.1 in. LCD Television
How to watch laptop in my Sony Bravia?
you need to clone the acer screen using ati utility
Jan 26, 2009 | Televison & Video
Laptop to TV
I dont believe that you can hook that model up to a TV you have to have a certin video output and it also would depend on your tv as well. But i am about 100% sure that series does not have the output you need you usally can connect via S-cable
Dec 04, 2008 | Dell Inspiron 2200 PC Notebook
i have same problem.
tech support couldn't work it out, so i have to send it back....
hope to get any idea.
Jun 26, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
