Question about GE 28300 Phone
Computer desk doesn't work
My usb cannot connect to my computer...
  • 108 Answers
Dwnld USB2.0 driver
Posted on May 23, 2009
My nextbook ares 10l keyboard stopped working
If your USB Keyboard stopped working, you can try to disconnect it and connect it back on the fly. USB connections are plug and play, so if you are running Windows and your USB keyboard doesn?t work, you can try unplugging and plugging it back to re-establish the communication, or simply try connecting it to another USB port. If this still doesn?t work, check the led lights on the keyboard; are any of them on? If they are, is the computer acting slowly? You may need to restart it at this point to refresh your computer memory and resources to get it back to normal speed, or perhaps it needs maintenance by running disk cleanup and defrag it
Nov 28, 2016 | Nextbook Tablets & eReaders
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Where do hook up wireless. I have dell desk top.
Hi and welcome to FixYa,
Almost always, wireless mouse makes use of the USB port to connect its base/receiver. Depending on the exact model of the Dell desktop, there would normally be USB ports at the rear of the computer. Some others have 2 USB ports at the front or side.
Good luck and thank you for asking FixYa.
Oct 22, 2009 | HP Wireless Optical Mouse
4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Jun 23, 2009 | Dynex 4-Port USB 2.0 Hub
Get message USB not connected when trying to scan
Right mouse click on my computer then click on hard were click ondevice manager, then click on port there may be yellow sign in usb port keepiung cd install it. 2/ if not work change usb cable to check ithink ucan solve your problem. 3 if not solve or u have desk top computer change usb card which we keep on on mother board slot. as amodeam and other card thank
Jun 19, 2009 | HP Photosmart C4280 Aio Printer
Pen drive not opening
What Operating SYstem are you using? XP or Vista? An what service pack? (Check this by pressing the Windows key + the Paue/Break key together)
Firstly, if you are plugging the pen drive in to the front USB, try the USB ports at the back. Many times this works.
Secondly, It's a known problem that XP with SP1 doesn't detect many pen drives correctly.
If that's the case, download service Pack 3 from microsoft's site:
http://www.microsoft.com/downloads/details.aspxFamilyID=5B33B5A8-5E76-401FBE08-1E1555D4F3D4&displaylang=en
HTH,
Deboo
Jan 19, 2009 | Electronics - Others
GE 28300 Phone Logo
98 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
