Install dvd drive
Need to switch my cd drive already installed in my computer to slave position in order to install new sony dvd drive and be able to run both on my computer, not to familiar with performing these actions
  • 74 Answers
Refer to the picture below:
The CD drive should have 3 jumper pins labeled Master (MA), Slave(SL) and Cable Select (CL) at the back near the interface ribbon cable.  In this picture the green jumper is in the Master position.  To make it a Slave drive, you need to remove the jumper and place it in the middle pair called SL.  You may have to remove the CD drive if you can't access it while in the system.  When you put in the new DVD drive ensure that its' jumper is in the Master positon.  The drives will not work if both have jumpers in the same position.
Get back to me if you need more help.
Posted on Oct 19, 2007
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
Tip
Booting a bootable Windows CD/DVD for a fresh installation when the boot order...
There have been several times that people have been stuck with a virus infected or a corrupt Windows Operating System and are finding it very difficult to get a fresh installation because of a boot order problem. It could also be a clean working Operating System but the user just wants a new one. The PC, whether laptop or desktop, could be a gift from a friend or one that they have been using for some time.
In the case of a gift from a friend, it could be that a forgotten password has been set in the bios and all has been done by the user to gain access but to no avail. There are also situations whereby the boot order is set alright to boot from CD/DVD but the PC just fails to boot from the CD. In these cases, even thought the bootable CD/DVD is in the drive, the PC just boots straight to the unwanted Operating System but you know that your CD/DVD drive works fine.
Here's what to do:
Obtain appropriate screw drivers and carefully remove the hard disk from the laptop or desktop. Now Obtain an appropriate external hard disk connector for the type of hard drive you have. In the case of a desktop hard disk, you could easily connect it as a slave hard drive in another available desktop by setting the jumper to the slave position (could be primary slave or secondary slave depending on the drives in the PC).
Try and backup any important files from the hard disk or from the partition with the Operation System in the case where more than one partition exists on the hard drive. When that is done, then you will need a Hard Disk or Partition Management Software like Windows Disk Management(which can be accessed by right-clicking on 'My Computer' and selecting 'Manage' and the 'Disk Management' in the resulting window). You can also use a third party software.
Now delete the partition and create a new Partition (Primary Partition). Then format the partition (NTFS file system recommended). When this is done, disconnect the hard disk and fix it back into the PC. Now you are ready to install a fresh Windows Operation System. Turn on the PC, Insert the bootable Operating System CD/DVD (e.g Windows XP) and there you go: your PC will automatically boot from the CD/DVD.
Wish you all the best.
on Dec 31, 2009 | Computers & Internet
How do I install an extra SATA cd/dvd drive in my PC
Hello, I will be the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Peter Symonds.
Read the big label that the manufacture has put on your DVD drive, you need information regarding Master and Slave jumper positions.
You need to set the main DVD drive as Master and the other as a Slave or secondary drive. However some-times this configuration is set in the BIOS/CMOS of your computer system.
Install the drives by removing an available 5.25" plastic drive cover on the front of your PC tower case. Now secure the new DVD drive to the chassis with the included M3 mounting screws.
Use two screws on each side to ensure that the drive is secure.
Insert both the SATA power and Data connections into the drive and the SATA data connector into an available SATA connector on the mainboard.
Once completed power on your computer and enter the BIOS/CMOS by tapping the delete key as soon as your computer powers on.
Your will get to the BIOS/CMOS screen where you need to find the heading for Master and Slave drives. You should see your primary hard drive and both DVD drives.
Enter into the DVD drive settings and set the one to master and other to slave.
Save and exit setup, usually F10. Read options at the bottom of the BIOS/CMOS screen.
It's as easy as that.
Take care!
Jan 30, 2012 | Dell Dimension E520 PC Desktop
I have used my maxtor 8 as a slave. I now wish to use it as a normal drive. My attempts to install XP produces an indication that NTLDR is not present. I have managed to start the installation program but...
If you had it set to slave status, there is a jumper on the drive controller next to where the cable plugs into. that jumper needs to be set to the correct position. typically there are 3 jumper positions Master, Slave, and Cable Select. If this is the only drive in the system, you can set it to master or cable select position. If there are multiple drives, then every drive needs to be set to cable select.
The diagram on the drive label should tell you which jumper is cable select position.
Oct 04, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
WHY MY DVD-RAM CANNOT READ DVD
you have it set in RAM mode, which is it is being operated as a extra hard drive. you will need a optional software/driver package (if your pc/laptop) don't have it already, in order to set it back to cd/dvd mode. incidently, that software/driver is hard to come by.
look for as "dvd-ram driver download"...
May 08, 2009 | Sony Optiarc AD-7170S Burner
Missing bios, and power supply/switch problem
Hi Jim!
First of all I'm from Sweden and I'm writing this 3 o'clock in the morning so there might be some spelling errors ;)
Yes, the powerswitch can be a real pain. since you need the schematics of your specific motherboard... to get this you need to know what model your board are. typically its written somewhere on the board with slightly larger letters/numbers than the rest, OR, if it's a typically brand computer (HP, COMPAQ, DELL, IBM etc.) with its original board you should be able to get the model number by just looking at some number on the computer case. example: DELL OPTIPLEX GX270 and seaching for that computer model on ther website. can't promise that they will give out any schematics though...but its worth a shot ;) If you cant find any schematics for your motherboard just post the model of your motherboard here and ill see if i can provide some feedback about it...
About the CD/DVD, try to boot with just 1 device powered up at a time, since basically CD's and DVD's are the same when it comes to interfaces like IDE. so either go with the DVD player OR the CD-ROM player to make it easier to find out whats wrong. After you have installed XP successfully you can try to connect/add the other device and boot up the computer again -XP should install it automatically.
Furthermore with the DVD or CD (whichever you want to try installing XP with). the cable connecting it to the motherboard and the DVD/CD should be in the SECONDARY IDE port on the motherboard (PRIMARY IDE port is for the HDD -Hard Disk Drive) and the jumper or "plug" on the dvd should be set as MASTER (should be a sign like "MA" or something, usually theres just those two pins that needs to be connected) there should also be others like SL for SLAVE and CS for CABLE SELECT but you wont need to bother about them. Master means the primary drive (the one that boots first on that channel, when installing win xp for example, this drive is the one that should contain the CD or DVD) Slave means a secondary drive - works as normal once in windows but is not preferred to install the base OS from. Cable is meant for the motherboard to decide wheter the device should be master or slave depending on which port on the cable it is connected to. also with the IDE cables; the port that are farthest away from the motherboard connector is the MASTER port. a rule which is not so clearly described.
You might need to enter the BIOS too to select the DVD drive as the default booting device in the boot order... usually its ranked from the top where the device on the top of the list is the one booting first.
Regarding the "NTLDR missing" (NT Loader) problem its just a file in the windows structure that is not recognized since you installed the OS (Operating System) in another computer.
Installing Win XP to a harddrive in anoher computer will most likely not solve your problem, as Win XP is based on the NT (New Technology) it isn't as flexible as older systems eg. Win 98. Your only real shot of succeeding in this matter is to simply install on the very computer that should hade this drive by default. (read: the computer your having trouble with)
Hope this helps out somehow, it would be nice to hear how this project ends up.
PS. For the record, my haircolor is blonde ;)
Hope this doesnt discourage you too much after reading this confession.
Best regards
Dan
Nov 04, 2008 | Computers & Internet
AW-Q170A-B@ Sony DVD RW Atapi CD/DVD ROM drive
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 21, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Computer can't find it
hi ...
try to change jumper position to slave or to master and start up you xp pro
good luck
Oct 22, 2007 | Samsung SW 240B CD-RW Burner
Installing dvd drive
When you connect two drives to a IDE cable, one of the must be 'master' and one 'slave', whichever is master will show up first and slave will be second.
If you're only using one drive, it needs to be set for 'single', (which may or may not be the same as 'master'.
Look on the back of the drives, near where the cable plugs in, and there'll be some pins with jumpers on them, there may be a C M S (in any order) by the sets of pins, the M and S are for Master and Slave.  The C setting requires a special cable, so we won't worry about it.  There may be something on the drive's label that says what the proper jumper setting is, check there.
Oct 19, 2007 | Systemax AOL Optimized PC (100607) PC...
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
