Question about E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC
Eflite 60amp esc - no throttle responce
Hi, I have purchased the eflite ****** and have installed an eflite power 32 motor and eflite 60 amp esc. The battery I am using is a flightpower 4s 14.8 volt 3300. All servos respond fine but I have no throttle responce at all ! Can you help ?
Lower throttle trim all the way. It will arm like a charm.
Cliff
Posted on Jun 24, 2010
  • mamaunm Aug 15, 2011
    Indeed, it worked like a charm! Thanks for this simple tip- it's a failure on E-Flite's part not to mention this.
  • 44 Answers
You should contact E-Flight RC:
http://www.e-fliterc.com/About/Contact.aspx
If they can't help you, you should consider returning your ESC and/or motor.
Posted on May 24, 2009
How To wire a cutler-hammer A/C Disconnect Box 60amp-240V Non- Fusible
"LINE" is typically the incoming power.
"LOAD" is typically the outgoing wires to the machine.
Sep 19, 2014 | Cutler Hammer DPU222RGF 60 Amp Out A/C...
On what overload amps wil a 60amp main breaker trip
Breakers are not fast-acting.
Generally they will let heat on the wire build up slowly that can slightly exceed the actual 60 amp rating.
But amp draw exceeding 60 amps cannot last long before it will trip... each event can be different with no exact answer available.
Also if the breaker is worn out or loose on the busbar, it can trip before amp rating is reached.
Use 6 gauge wire with 60 amp breaker
http://waterheatertimer.org/Color-codewire.html
Gene
h
Aug 10, 2014 | Electrical Supplies
Need information on circuit breaker BR2100 60amp
Hi - I'm an electrician and can help you with your question.
A BR2100 circuit breaker is a 2 Pole 100 Amp (for the part number "BR2100", the "2" indicates the number of poles and the "100" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
A BR260 A BR2100 circuit breaker is a 2 Pole 60 Amp (the part number BR260, the "2" indicates the number of poles and the "60" indicates the amperage) circuit breaker. It can be installed in a single phase or three phase 120/240 VAC system panel that specifically lists the BR series breakers as acceptable for use.
It is not possible to have a BR2100 rated for 60 amps, 1 or 3 poles, or a BR260 rated for 100 amps, 1 or 3 poles.
It is not permissible to install any circuit breaker brand or type in any panel that does not specifically include it on a list of acceptable circuit breakers.
Circuit breakers are designed to carry 80% of the amperage rating.
To determine the load a circuit breaker can carry, multiply the circuit breaker amp rating by 80%.
This means that if you need to supply more than 80 amps, you cannot use a 100 amp circuit breaker. A higher rating is required. A BR2110 would be acceptable for loads greater than 80 amps, but less than 88 amps because the formula above says: 110 amp x 80% = 88 amps.
To determine the breaker size, determine the load (by measuring with a meter or obtaining amp rating of the load from the data plate) and multiply it by 125%. Using the same numbers in the example above; assume an 88 amp load. 88 amps x 125% = 110 amp circuit breaker. The 60 amp breaker is acceptable for up to 48 amps because 60amps x 80% = 48 amps. A 48 amp load needs a 60 amp breaker because 48 amps x 125% = 60 amps.
I hope this helps and good luck!
Jan 15, 2013 | Eaton Corporation BR2100 Circuit Breaker
I have an ezgo electric golf cart and I have now replaced the 60 amp link fuse that connects to the battery and black wire. When driving the golf cart just quits and when checking the fuse is blow. Th
This is not a car question, but generally speaking a fuse blows when the current in the circuit exceeds the limit of the fuse.
I would look at the amp draw of the motor if that is what runs on that circuit and also the connections. It could be that the motor brushes are wearing out and the motor is pulling too much current.
I'm somewhat lost on your description - - you say it is a 60amp fuseable link but you bought 20 amp fuses. Are you dealing with two different circuits ?
Jul 24, 2012 | Cars & Trucks
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
I have an Electric Furnace rated at 45 Amps/240v. Would a 45 amp breaker suffice for this unit?
Most likely not.Heating equipment circuit breakers have to be calculated at 100% of the load continuous. That would mean the circuit breaker would have to be rated at 45amps continuous. Most breakers are not. Most breakers are rated at 80% of their rating for continuous loads. So if you installed a 60 amp circuit, 80% of 60 = 48 amps. This would fit your requirement. That would be a 60amp breaker, with #6 cu conductors.
Oct 31, 2010 | Sylvania Circuit Breaker
Erra code 60 appears when I start my 2007 r1,also engine management light appears and bike has no throttle responce
Fault code No.: 60
Symptom: Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system).
Probable cause of malfunction:
•Open or short circuit in wire harness.
•Defective throttle servo motor (potentiometer circuit).
•Stuck throttle servo motor (mechanism).
•Stuck throttle servo motor (motor).
•Malfunction in ECU.
Diagnostic code No.: 01
FIRST thing to do is CHECK the ETV Fuse - 7.5A I think - This might NOT be in the main fuse box.
Hope this helps
May 07, 2010 | 2007 Yamaha YZF-R1
Tail light are not working
fuses under hood
POWER DISTRIBUTION BOX Location Name Amp Circuits Protected A Trailer Tow 50 Fuse 32/Fuse 26/Electric Brake B Fan (Hi) 60 Cooling Fan (CCRM) C Start 60 Starter Solenoid/Fuse 30/Fuse 36/Fuse 2 D Ignition 60 Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33 E Rear
Blower/
RAS 60 Rear Heater Blower Motor
Rear Air Suspension F Seat 60 Power Seats G — — Not Used H Fan-Lo 40 Engine Cooling Fans J Power Accessory 60 Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19 K Light 60 Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17 L ABS 60 ABS Control/Pump Motor Module M Heated
Backlight 60 Heated Backlite/Fuse 16/Fuse 28/Fuse 22 N Fuel 20 PCM/Fuel Pump/CCRM P — — Not Used R PCM 15 PCM Memory S PCM 30 AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV T Alt./Reg. 15 Generator U Air Bag 10 Air Bag (Dedicated) V Trans. Light 10 Transmission Indicator Light W Fan 10 PCM Fan Monitor X Diode — Hood Lamp Diode Y Relay — RH Trailer Turn/Stop/Hazard Lamps Z Relay — Powertrain Control Module AA Relay — Windshield Wiper Speed BB Relay — LH Trailer Turn/Stop/Hazard Lamps CC Relay — Windshield Washer Pump Motor DD Relay — Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps Color Code 4 Pink 5 Tan 7.5 Brown 10 Red 15 Light Blue 20 Yellow 25 Natural 30 Light Green 40 Orange 50 Red 60 Blue
Mar 14, 2009 | 1997 Ford Windstar
Alternator charging system
try the 60amp fuse under the bonnut there is a 30/40/50/60 amp fuse,s there the 60 amp is the charging fuse. i had the some thing it was the 60 amp fuse its all ok now the alternator fuse ok 60 amp.
Jan 31, 2009 | Suzuki Sidekick Cars & Trucks
E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC Logo
786 people viewed this question
Top E-Flite Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an E-Flite Electrical Supply Expert? Answer questions, earn points and help others
