Question about Toshiba E-Studio 3511 Color Copier
{place doc .feder in the down postion }
I have toshiba es45 problem is {place doc .feder in the down postion }
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; there have a document senser when you feed the document, check the senser may be it come off or broken.
Posted on May 23, 2009
It shows in the screen place doc.feeder in the down posotion
90% it is the RADF PCB. Before replacing it check the sensors and switches of the RADF in 03 mode. Refer to page no 2-29 of SERVICE HAND BOOK.
Dec 05, 2012 | Toshiba e-Studio 232 Black and White...
Giving error place doc.feeder in the down position
problem with the feeder sensor >>top at the arrow
May 07, 2011 | Toshiba estudio 305 Copier
I'm getting a "PLACE DOC. FEEDER IN DOWN POSITION" message when I place a document in Doc Feeder input tray of my Toshiba E-Studio 3511 copier. It is down. I have removed and reinstalled the feeder...
On the rear left side of the copier there should be a black hinged actuator sticking up out of a hole in the panel, directly opposite of that there should be a white plastic tab that pushes that actuator down. If not try taping the actuator down flat with the cover.
Jul 12, 2010 | Toshiba E-Studio 3511 Color Copier
Can Federal Pacific ni breakers be used in place of nc?
I honestly wouldn't recommend using Federal Pacific in the place of anything. If you go to your local home store they may be able to help you out with a solution of what breaker to use. Federal pacific is being removed from any old construction where its found because Federal Pacific breakers are many times faulty and don't trip when they should resulting in a fire.
Apr 11, 2010 | Pacific Industrial Federal Pacific 50 Amp...
Place doc , feder in the down postion
Something is blocking the Original Present sensor in the document feeder. The machine thinks you are trying to use the doc. feeder to make a copy. Clear the obstruction and this should remedy situation.
May 23, 2009 | Toshiba E-STUDIO 450 Copier
The copier keeps saying to put doc. feeder down and i it is. I ha
power supply has the fuse open that feed the voltage for the ardf
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
Jan 05, 2009 | Toshiba 2060 Copier
Printer problem
Make sure your paper is of good quality and fan it before placing it in the paper tray. Clean the take up area with a soft brush to get rid of all the build up of paper dust, or vacuum it with a nozzle tool or soft brush tool. Do the same with the paper path and paper tray areas.
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
Toshiba E-Studio 3511 Color Copier Logo
78 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
