Question about Dell 924 All-in-One InkJet Printer
"CLEAR THE CARIER JAM"
There is nothing jammed
  • 564 Answers
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 23, 2009
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
P4350
The carrier slides back and forth on a bar that must slide smoothly. When you open the printer up, the heads come to the center for cartridge removal, so that part of the bar is oiled. Try lightly spraying a silicone or Teflon spray or a drop of high quality machine oil to the bar where the head will go through it, smearing it along the the bar. Another part is the plastic belt with teeth on it that moves the head from side to side. If the teeth have broken off, the head won't move properly. Some of these printers have an entire head assembly where the cartridges set that can be removed after the cartridges are out. If this print head assembly is damaged or worn out you will also get the error. The head damage is usually because some one yanked jammed paper vigorously out, pushing the head out of position, or the print head was moving when something stopped the head.
Aug 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
Carier Jam
Sounds like the carrier sensing strip (It tells the printer the location of the carrier) most likely time to replace
Apr 19, 2010 | Dell 926 All-In-One InkJet Printer
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
Paper Jam at A but nothing there
If you clear the jam and close the machine up again, does the print job eventually print OK. You may have to clear the jam several times before the machine prints it successfully. After the first successful print, does the machine then print ok, until the next time it is left idle for some time? If this is the case, I have a fix for you
Nov 07, 2008 | Epson AcuLaser C3000 Printer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
"Paper Jam"
Your printer is still trying to print whatever preceded the paper jam. Go to Settings/Printers/your printer/ and clear all documents in the printer que. You will also have to shut down the printer and restart the computer after this to be sure.
qwester
Aug 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Carriage jam
your printer is having hardware problem,please get it serviced with printer professional or to the vendor
Apr 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Says paper jam but there is nothing in there
Can you tell me the jam code (if any), or where it is saying it is jammed?
Jan 10, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
