Question about Alps DF354H (DF354H168) Internal Floppy Drive
Computer does not detect a Alps Electric Co. Floppy drive
I'm trying to add a alps electric 3.5" floppy drive to my dell optiplex 170L computer.I went into setup and set Drive A to "3.5",1.44Mb Floppy Drive",and installed the drive.When I boot the machine up it does not see the drive or any new hardware.Any help will be greatly appreciated.Thanks
  • 202 Answers
Check the data cable and power cable,does the light in the floppy stay on if so you have the power cable backwards.is the drive connected ot the right end on the data cable. if the answer to these are yes then you have a bad drive.
Posted on Jul 23, 2009
My Dell optiplex 210L boots up into a menu that says floppy seek failure strike f1 to continue f2 to run utility
You took your battery out and your computer lost all memory of what components it has installed. Hit F2 to get into the System Bios Setup. Look for your Disk drives and you will see your floopy disk drive there also. You should set the Floppy to Not Installed or None. It is probably set to Auto or 1.44.
Mar 18, 2012 | Dell OptiPlex 210L PC Desktop
Dell optiplex gx110 will not start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps you
Mar 15, 2012 | Dell OptiPlex GX110 PC Desktop
Dell optiplex gx 620 powere went out last night and this morning it won't turn on. The only light I see is on the motherboard and its solid yellow
hope this helps you
Nov 30, 2011 | Dell OptiPlex GX620 PC Desktop
I need to replace the 3 1/2" floppy disc drive for
This should be easy enough to find with a web search on your part number... but it is very likely that almost any floppy drive will work, as long as it mounts in your location.
May 18, 2011 | Computers & Internet
My pc Motherboards problm
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Dell Optiplex GX280 (99301) Motherboard
Diskette drive 1 seek failure
It sounds like the 3.5" floppy drive either got disconnected (if you were inside the computer) or it went bad.
I the easiest fix (if you don't use the floppy drive) is to disable the floppy drive in the BIO's.
I don't have the exact steps for this particular model Dell BIO's but here are some basic pointers.
When the computer first boots up you should see an option to enter SETUP (probably by hitting F2, or DELETE or F10, etc). Once in the BIO's look for the floppy disk setting and simply set it to NONE or DISABLE (what ever option they offer).
I hope this helps.
Best of luck!!
Mar 01, 2011 | Dell OptiPlex GX110 PC Desktop
Dell optiplex GX280 decommissioned and hard drive formatted to remove business records. MS Windows XP Professional reloaded and the computer was restarted as per instructions. Nothing at all happened. No...
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Dell Optiplex GX280 (99301) Motherboard
When started system show . 0seek driv failur
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 21, 2010 | Dell OptiPlex GX260 PC Desktop
Dell GX260
You need to change the boot order in the bios of the computer. It is also called the setup. When you turn the computer on, in the top right hand corner of your screen you will see F2-Setup F12-boot menu. Select F2 and when you get into the bios go through the options until you find "boot order" or just "boot". That will show what devices your computer will use, and in what order, to boot up. If the floppy is below the main hard drive then it won't work unless the hard drive is defective. Move the floppy to the top of the list, exit saving changes, and it will now check the floppy first.
Dec 11, 2008 | Dell OptiPlex GX260 PC Desktop
Read/write low density disks
Nothing, the machine worked with the DS1 too
Apr 28, 2008 | Alps DF354H (DF354H168) Internal Floppy...
Alps DF354H (DF354H168) Internal Floppy Drive Logo
310 people viewed this question
Top Alps Computers & Internet Experts
David Payne
David Payne
Are you an Alps Computer and Internet Expert? Answer questions, earn points and help others
