Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this.
As you increase the volume, you will increase the amount of current you
are drawing from the receiver. To troubleshoot this issue, try the
following:
Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
Check the impedance of the speakers; make sure they are properly
rated for your stereo. In most cases, they need to be 8 ohms. Only a
few Pioneer receivers will support lower impedance.
If the problem still continues, try these steps:
Turn the receiver off.
Remove one speaker.
Turn the receiver on.
Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different
speaker each time). If you disconnect a certain speaker and the
receiver no longer overloads, have this speaker checked at a service
center. It could have a bad speaker component, like a tweeter,
sub-woofer, or even a bad crossover.
Yeah I just spent the last hour taking the lot apart and removed the bananna plugs i had for the mains, it seems to have cleared up.
