Question about Lenovo IdeaPad S10-1211U Netbook
Lenovo S10 netbook wirless connection problem
My Lenovo S10 netbook running Windows XP can detect & connect to Adhoc computer to computer wireless network but it fails to connect to other computer in the same network. Tried pinging at their respective IP addresses from both sides but to no avail. And both computers have the same workgroup name.
  • Lenovo Master
  • 32,281 Answers
Check the IP configuration of both computers, they should have the same address range if not it needs to be changed.
ON each computer click on Start - Run and type cmd and press Enter.
This will open a DOS box, then type "ipconfig" (without the quotes)
The IP address range should be the same on both computers (ie the first 3 groups on numbers in the IP address has to be the same on both computers) only the last group has different number.
Get back to me if you still have problems.
Posted on May 23, 2009
Why is Fn + F5 key function not working?
You probably have to download and install Lenovo Energy Management.
If you have Windows 7, you can download from this link: http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/S10-3/IN1EGC26WW5.exe
Use this link if you have Windows XP: http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/S10-3/XP/IN1EGC22WW1.exe
Save it to your harddisk and right click and run as an administrator to install.
Aug 15, 2014 | Lenovo IdeaPad S10-3 Netbook
Tip
HOW TO CONFIGURE WIRELESS ADAPTERS TO ADHOC MODE
Don't have a router and want to connect the two wireless computers with each other you need to set up both computers to an adhoc mode.If using Windows XP in your desktop computer follow the steps below to configure the wireless adapter to adhoc mode.
Go to control panel> Network Connections> Right click on wireless network then hit properties> Click on Wireless network Tab and removed everything under preferred networks. Click on Add button then type on the Network name SSID "Linksys". Remove the check for "The key is provided for me automatically" then enter the network key. Make sure that you enter 10 or 26 characters on the network key box. You can only set a network in using alphanumeric characters. You can create a network key by using numbers only,letters only or combination of numbers and letters from 0-9 or A-F characters. Put a check mark on the box says "This is a computer-to -computer (adhoc) network." Hit the ok button. Under the preferred networks highlight the SSID that you have set "Linksys"then hit the advance button. Click on computer to computer [adhoc]networks only then hit close and ok all the way out.
You need to do the same thing on the laptop where you have the installed a wireless adapter. SSID and network key should be the same on your network card. It should be set to adhoc as well.
Both computers must have static IP address. For the desktop computer you can set an IP address of 192.168.1.2 and the subnet mask is255.255.255.0. The laptop must have an IP address of 192.168.1.3 and the subnet mask is 255.255.255.0.
From the desktop computer, under network connections right click on wireless network connection then click on view available wireless network. Highlight Linksys then hit connect. Do the same thing on the laptop. Once they are both connected try to ping each other and see if you will get reply. To ping the laptop from the desktop computer,follow the steps below:
a.On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
b.On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.3 then hit enter.
Do the same thing on the laptop but instead of pinging the 192.168.1.3you need to ping the 192.168.1.2.
If you got replies it means that you are already communicating with each other.
If you are getting a low signal you may change the channel on the adapter. Follow the steps below on how to change the settings of the adapter:
For Windows XP and 2000
Right click on my computer properties>click on hardware>device manager>under network adapters right click on wireless-G notebook adapter then select properties>click on the Advance Tab then look channel then change it to 11. You may try to use other channels like1, 6, and 9.
For Windows 98 and ME
Click start>control panel>network>look for wireless-G notebook adapter with a green icon left beside it then double click on it>click on the Advance Tab then look for channel then change it to 11. You may try to use other channels like 1, 6, and 9.
Hope this help everyone.
on Jan 26, 2010 | Computers & Internet
How to install drivers for my lenovo s10 ideapad webcam (1024x600)
goto website: http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers.html
Mar 27, 2012 | Lenovo IdeaPad S10-1208Uw Netbook
I can t to conect my lenovo s103 wi fi
Hi elyflorin200,
I see that you have the s10-3 Netbook and that you wants to connect using Wifi.
  • On your Netbook make sure that the wireless switch on the side is switched on first.
  • On the lower right hand side you should see a wireless icon that looks like a signal bar indicating that your wireless is on and that it detects Networks in the area.
  • Point your mouse cursor on the signal bar on the lower right it should say Networks are detected or connect to a network.
  • If you do not see the signal bars then the wireless may still be OFF on your Netbook.
  • Try and Press FN+F5 the same time you should see a windows that will pop up saying Networks or it should say Wireless device or the name of your of your wireless card, check if the wireless is enable or turned on under current status.
  • If your S10-3 detects Networks click on you Routers name to be able to connect wireless it will prompt you for a security if in case your Router has a Network key or Security key you will need to type that in in order to get internet from he Router if ever you enter the incorrect Network/Security key i will give you an error.
  • If ever you get connected it will prompt you if you want to save the Network and if you want to connect Automatically put a check on Connect automatically so that every time you turn you S10-3 ON it will detect the wireless signal in your home.
For further information regarding you s10-3 you can to this link below http://consumersupport.lenovo.com/us/en/UserGuide/Guide_list.aspx?CategoryID=686287
I hope that this will be helpful regarding you question.
Have a nice day.
Mar 15, 2011 | Lenovo IdeaPad S10-3 Netbook
I have a Lenovo S10-3t ideapad with a Broadcom 802 1.1n wireless adapter, My router is a Netgear DGN2000 with b&g modes. I can notv connect the Lenovo to my router, even though it detects the router....
For lenovo computers, Try to look for Lenovo Readycomm software and uninstall it. Restart your computer and try reconnecting. Its still better to use the wireless connection software built in with windows
Jun 12, 2010 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
I have lenovo Ideapad s10-2 which can't connect or find wireless network , pls help me
me too. my purple lenovo S10-2 can't detect wireless network but my sisters' HP can detect the wireless network.
Dec 30, 2009 | Lenovo IdeaPad S10e Notebook
Windows is not detecting usb mouse and mouse is not working
which OS you have..? xp/2000 , both OS not need USB driver but auto detecting.., i request you to try another usb socket.
Jun 28, 2009 | Lenovo IdeaPad S10-1211U Netbook
Inablitlty to connect to other computer in adhoc wireless network
if the network is hosted by the lenovo s10 try connecting from the other computer also it would be helpful to tell us what operating system you are running on both computers at any rate here is a link that solved the problem for me. http://www.vistax64.com/vista-networking-sharing/108893-ad-hoc-computer-computer-wireless-network.html if that doesnt help or pertain to your operating system do a search on the same site under your operating systems. good luck and hopefully if you dont fix it someone with more knowledge comes along to help
May 24, 2009 | Lenovo IdeaPad S10 - 42312BU Notebook
Connecting my linux machine to a windows xp based wifi network.
if im not mistaken u have to set up a network connection and save the settings and load them into the next computer u want to be linked. windows network wizard should explain it quite easily.
Nov 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Lenovo IdeaPad S10-1211U Netbook Logo
553 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
