Question about HP Pavilion Media Center a1320n PC Desktop
Pc working slowly with 2gb ram - HP Pavilion Media Center a1320n PC Desktop
    Master:
  • 118 Answers
Step 1:-
Go to
Start > Run>
type "msconfig" >uncheck all except ur sound & display drivers then click Apply > Ok
Step 2 :-
Right click on My Computer Then select advance tab
>performance settings>select advance>click Change > click on custom size then double the values then click ok
And Ur Done
Posted on May 23, 2009
  • 105 Answers
Download this.http://www.ccleaner.com/download
its free and spyware free, you dont have to install yahoo tool bar so uncheck it if you dont want it. go thru all tabs and clean computer, scan and fix registry errors. after complete Go into control panel.....open system icon......click on advanced tab.....click on preformance settings tab.....click advanced tab again....click on virtual memory change button...check custom button, change min size to 3000, max size to 5000. this will make 5 gig of hard drive to be used as more ram
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
White screen
the beginning of ugly problems you will need a new video driver card and screen within about 3 to 6 months
May 28, 2012 | Dell Inspiron 1545 Black Intel Celeron 900...
Question Problems with DIMM slots !!!
Hello
Try installing the memory on one memory slot at a time to make sure that both memory slots are working ,try one memory by itself and then the other one.
If you install both at the same time example 2x 2gb ram and bios only sees 2gb and not 4gb then it's problem with one of memory slots and motherboard must be repaired.
You can try bios update:
http://www.msi.com/product/nb/EX630.html#/?div=BIOS
Good Luck
Feb 20, 2012 | MSI Computers & Internet
Dear Expert, I have Asus motherboard P5S800-VM. Now,There is 1.5 Gb ram(512MB+1 GB).If I plug 2Gb ram (1+1), then PC is working very slowly.What can I do for this problem . ram:2x1Gb Kinsgton thanks
First verify that you are using the proper speed of RAM. Second, check the BIOS and make sure that recognizes the RAM you have installed. Sometimes you have to manually set the RAM size in the BIOS in order to get it to work. Finally, I have had several issues with Kingston RAM on different motherboards even when it is the proper type so you would want to try a different manufacturer.
Jul 08, 2011 | ASUS P5S800-VM Motherboard
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
Just tried running restore and now have blue screen
Compaq are a bit fussy with RAM and usually don't like mixed RAM - brand, speed, & sometimes size.
You model may not support more than 2GB, check the specs..
Try inserting a single 2Gb RAM to see if it works.
If it dosen't work and the laptop won't support more than 2Gb, you may need to install two 1Gb RAM modules.
May 20, 2009 | HP Compaq Presario C500t Notebook
Connecting blu ray dvd from pc to tv
How much memory do yo have? For a really good showing, you should have at least 4GB RAM. (The max for 32-bit operating systems. Also, when you play your movie, I would suggest closing any application that you do not need running in the background, especially if you have less than 2GB RAM. Good Luck.
Feb 09, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
HP Pavilion DV2000 running very slowly
Yes! I would not recommend anything below 2GB at minimum. I have one laptop with 2GB and one with 3GB: they both open programs and browse the internet very quickly. Even with just two programs open (Internet Explorer and Outlook 2007) it uses 1.1GB of memory.
Definitely upgrade your memory. I recommend this site:
http://www.4allmemory.com/
Just pick your model and they recommend the memory to pruchase. TIP: order with next day shipping - it's only $10. The free shipping takes 14 days. So unless you're patient (I'm not) the $10 many be worth it.
May 29, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion Media Center a1320n  PC Desktop Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
