E-Machine Computer Sir......... I can not get power to the rest of the system.. I check the power cord, I ran a check of 110 Volts into the cirucut board, good. I stopped there. Is there a fuse? circuit breaker?
Can some one help me my screen went out on my computter thought it was the screen replaced it and still no power comeing to it....Thank you
Posted on Dec 26, 2007
  • cwilkes Dec 26, 2007
    Is there any fuses in the computter tower to the screen and if that is the promble them will a new cord fix it...
  • 38 Answers
You need to test the large connector from the powersupply to the circuit board inside the computer. You should be reading small single volt numbers. More than likely its a bad powersupply though.
Posted on Oct 25, 2007
Dc011 radio works with battery but wont work when plugged in what could it be
Sounds like the mains transformer has gone. That is what reduces the mains outlet power of 110 volt to that of the batteries.
You could check the power cord though for 110 volts at the end.
Oct 31, 2015 | Dewalt DC011 AM/FM Radio
I am having trouble with power on my 1090s. I can sew for a short while and the machine goes dead. If I shut off the power and wait a few minutes it comes back. It doesn't if I leave the powe
Interesting. Have you tried plugging your machine at home into a different outlet than the one you normally use? It could be that the issue isn't your machine, but the outlet you have it plugged into.
If it still acts up, maybe try at a friends house, see if the machine does the same there. I was told by my handyman that home electricity can be "dirty" -- as in, 110 volts can fluctuate at the outlet. You might not be getting a full 110 volts (or too much) and that can affect small appliances. So even if your outlet is OK, maybe your home electricity is fickle and affecting your machine.
Jan 09, 2018 | Sewing Machines
Do jamo powered subs work in the u.s.a. on 110 volts 60 hz
just buy a adaptor like a normal plug socket that your 2 pin 110 volt can plug into it then plug it in to the 3 pin 240 volt socket an bobs your uncle your sorted.
Jan 25, 2013 | Jamo A320 Hcs6 Home Theater Speaker System...
I accidentally plugged computer avr 220v to 110 could it affect my power supply
If the computer power supply is a 240 volt unit and you plugged into 110 volt mains the the computer should be OK.
Some power supplies have a voltage selection switch on the back of the power supply switch to 110 volts and it should work.
If the power supply is 110 volts and you plug it into a 240 volts mains then you will damage the power supply and possibly the computer as well.
Mar 14, 2012 | HP Pavilion a465w-b PC Desktop
Whirlpool electric range super capacity 465 RF 377PXGQ0 SER# RH 4718582 the stove burners work nothing else works the control panel and oven are not working at all no lights at all... everything...
Ok
you must have a problem with you neutral leg .
Check to mak sure all 3 wires from power cord are securely connected to machine. Next make sure recepticle at the wall
has a good neutral. Use volt meter to check your recepticle.
You should get 110 volts between any top and the bottom slot.
No 110 volts means check house wiring or recepticle
Yes 110 volts means problem with neutral wiring in machine.(Not likely)
good luck
Jul 26, 2011 | Ovens
All the little lights flash,but it wont start
some Bosch washers are rated for 220 volts and some are for 110 volts, open your door and check the rating tag by your model # and see what the voltage rating is. If you have the proper power rating then your problem may be with the lock assembly(door lock), you may want to unplug and let rest for about 5 minutes and plug in may reset computer bd.
Mar 10, 2011 | Bosch Washing Machines
I have a kenmore 110 6262200 I have replace both tstats, heating coil and then taped the thermofuse wires and still no heat...
Greetings,
did you check the voltage? the machine will run on 110 volts, but you need 220 volts to make it heat..The thing to check is the voltage..I have seen circuit breakers do this. The motor itself can keep the heater off. If you have a ohm meter . check the red leads on the motor itself..remove the red wires and only check where the red wires connect to the motor. If you get a reading its ok, if not, the motor switch is bad, but, its best to replace motor.
Its possible, after checking the above, that you can't still find the problem. Then, double check that you have 110 volts between,L1 and N and 110volts on L2 and N on the terminal block in the dryer where power cord attaches...i have seen the power cord go bad as well....The timer itself can cause this same problem. This is the last thing that I can think of that could keep your dryer not heating, that is if everything else has been checked and double checked.
Feb 03, 2011 | Kenmore 62602 Electric Dryer
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
No power for Sony ICFCD855V Dream Machine.
Power supply seems to be 12 volts. I have ICFCD855V's and the power cords on both broke just past the strain relief on the power supply. That shorted the supply and blew the fuse (1.6 amp). I soldered in a new fuse and the supply (with no load) puts out 12VDC. Since it happened to 2 in my house I can't believe Sony doesn't have a recall on these things
May 10, 2008 | Toshiba Sony ICFCD855V Clock Radio
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
