A nice ringtone named "Samsung Tune" inbuilt default tone of the Samsung Handset,can't be extracted or copied to PC for using with other handsets. Where can I find the same ring-tone? Is there any we
In current models of mobile-handsets of Samsung, I hear a ringtone named "Samsung Tune" which is very melodious. I want to download it and use it with my Nokia E51. As the tone is one of the default tones of the handsets, it can't be extracted/copied to PC. Where can I find the same ring-tone? Is there any web site link to get it from? I searched the related sites through Google-search but couldn't succeed. Pl help to get the tone.
-dushyant ajabia from Jamnagar.
I know there is also a midi file but it was copy protected so I can't send it from the phone.I know there is also a midi file but it was copy protected so I can't send it from the phone.
Thanks a lot, it was" the classic one" I had been searching since long and you have provided the link for it...! Heartly THANKS...! Both the links to d-load the tones are useful and both the tones excellent...Thx again, sir...!Thanks a lot, it was" the classic one" I had been searching since long and you have provided the link for it...! Heartly THANKS...! Both the links to d-load the tones are useful and both the tones excellent...Thx again, sir...!
alex, i want 2 files from the same phone but not the above listed one you provided. my phon wont opower up anymore so i cant recall the names. do you have the other titles? can you point me in the right direction? Thanks in advance!alex, i want 2 files from the same phone but not the above listed one you provided. my phon wont opower up anymore so i cant recall the names. do you have the other titles? can you point me in the right direction? Thanks in advance!
You can't post conmments that contain an email address.
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting. Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display. NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
The phone has 8 ring tones. From the idle phone, press PROGRAM and dial 99. Press the intercom or a CO line button TWICE and dial 2-8 on the keypad (1 is already default). When you're satisfied with the tone, press STORE. You have to do this for each line and the intercom you want to change and you need to do this at each phone. Pick up the handset and drop it back down to exit programming.
U must download these apss. like opera mini, bolt or other apss. from the internet using your phone's inbuilt browser which will install these apps to your phone automatically after downloading.....
Connecting tointernet
Get setting from yourservice provider first and then save and activate them as default....
Now select any planavailable there..and then you can surf net on phone.....
WARNING: Restoring
the handset will permenently
Delete All Data, including Contacts Note: All locked pictures, videos, ringtones, music, sounds
and downloaded content will be permenently deleted when restoring the
handset to the default settings. To restore the handset to the factory default settings follow
the steps below:
While in standby mode,
press OK for Menu
Select Settings &
Tools (9)
Select Phone Settings
(6)
Select Security (9)
Enter the lock code,
default password is the last 4 digits of cell phone number, unless
it has
been changed, then press OK
Select Restore Phone
(5)
Highlight Yes, using the
navigation keys
Press OK
to confirm resetting the handset
Press OK at the re-program the phone screen
Enter the lock code again,
it has
been changed
Press OK
to confirm restoring the handset to the factory default settings
Note: Press *228 and SEND after the power cycle to re-program
the phone Hope this was helpful?
Hi, to change the ring-tone on the SamsungProstar- with the handset down, press Transfer 111, press 1-8, 1 being the quietest upwards to 8, or use the volume key, press Transfer when you have finished. I have loaded a video for you to watch, showing how to do this, 'abbeytel' have nearly 70 like this on youtube all relating to training issues on the SamsungProstar. Go to
My problem was with a samsung j 700. I found a volume uitton on the side of the handset, which I turned fully down, and this did not affect the volume of the ringtone.
This is the best I can do to answer part of your problem. I solved my problem by taking this advice from Uniden for their dual phone set:
Selecting Ringer Tone (handset only) Question: How do I set/change my ringer tone on the handset? Answer: There are two different way to change you ringer tone depending on which model you have. If you do not have an option in your menu on you handset for handset setup, then you will simply hit the volume ^ or v arrows on the handset rapidly scrolling through the 2 ringer tones and volume combinations.
Ok, Might seem like a daft question but is it on silent?
I'm guessing you chekced this already but it's easy to miss.
The first thing to check is whether it will make any sound at all - this is a good guide as to whether the speaker is broke or just settings are wrong. Being a Walkman phone you might have some tunes on it so see if they play. Do this through the walkman/media player feature as apposed to the ringtone area.
If they play then you know it's still working and some settings need changing. If not your speaker might be broken.
If the speaker works then you need to check the ringer volume. this can be done from MENU/SETTINGS/SOUNDS&ALERTS/RING VOLUME - this then needs to be set using left and right to go up and down.
After this is set test call the handset to see. If still no luck change the ringtone to another tone - something built into the handset preferably - might be a faulty tune. If still no luck check the the number calling the handset has not got any sound preferences - i.e. no tune when call received. If still no luck it might be broke...
Yes i have sent to motorola's many times, activating the bluetooth on the v3 handset can be difficult or confusing, but bluetooth transactions can be made between any two bluetooth enabled phones.
i want that too. did you ever get it?
