Question about Dishwashers
LG DISHWASHER High Pitched Screech.
Recently I slightly moved my dishwasher to clean the top and since then there is a loud high pitched noise when I use it on wash and dry. Can you tell me what is causing this.?
Thanks
  • 3 more comments
  • Nicko2 Nov 20, 2007
    We have a new LG LD1403W with a similar high pitched whistle when filling. I am going to try and swap the inlet hose with our old one to see if it makes a difference.
  • Anonymous May 31, 2008
    I just purchased and LG dishwasher. It was installed today and it has a high pitched noise when running.
  • jawny Dec 29, 2008
    I have an LG dishwasher which makes a high pitched whistle. I've tried to locate it, but I can't, though if I pull on the wiring harness on the lower right side, it seems to stop, but of course, the whistle is intermittent so its hard to pinpoint. Its enough to drive you insane though, my wife wants me to return it
  • cbwoods Jan 06, 2009
    Same problem here, been happening for months, our unit is 2 years old, its so loud you cant be near it when running the cycle. The squeal starts whenever its pulling water in. :( LG = Load Garbage!
  • seanatouc Feb 18, 2009
    Has a high squeal about 50% of the time while running. I think it may be the bearings. Two years old and I have already had the motor replaced under warranty!
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
  • 351 Answers
SOURCE: High Pitched Noise
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
Posted on Mar 09, 2008
Problem is with the main pump motor bearing. Water leaking from the face seal enters the front bearing. After some time, the bearing wears out bringing on the loud noise. The motor is easy to remove but the bearing requires some time to remove. I did not have access to a press so I ground off the bearing an replaced it with a shielded 8mmx22mm type. Grainger p/n 1L001. The part is only $9 compared to over $200 for a replacement motor. It takes some time and disassembly of the dishwasher can be difficult but take your time and be ginger with the parts. The root of the problem seems to be the impeller. It screws onto the motor shaft and seems to work loose after time. Since its tightness compresses the face seal, when it loosens water can seep. No way to lock it in place after tightening. Weak design point.
Posted on Sep 24, 2008
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
BIKER T
  • 909 Answers
SOURCE: IT'S LOUD, HIGH PITCHED WHINE, RUNS FOREVER. I
Go onto the net and ask what the best dishwasher or recomendations are for that region.
Posted on May 18, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Lg 3850dd3006e makes noise
I had the same issue with my LG it has a stainless steel impeller the grinds up the food particles and if one of the veins get slightly bent it causes that problem. The tack took it out straightened it out until the new part arrived and it worked fine. He did return to replace it but I don't think it was needed
Jul 29, 2012 | LG 24 in. LDF 7811 Built-in Dishwasher
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Feb 23, 2008 | Dishwashers
High Pitched Noise
Feb 06, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Dishwashers Logo
1,695 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
