Question about Panasonic KX-T7730 Corded Phone
I want to change my extension from 109 to 111 using kx-t7730
I want to change my extension from 109 to 111 using the kx-t7730
  • Panasonic Master
  • 2,460 Answers
With any luck, you have a TA series, or at least an non TD/1232/TDA100 system that the phone is plugged into. The quickest way is somewhere in the back room, jack 09 and jack 11 are on the same card and right next to each other (with 10 in between). SWAP THE PLUGS.
Of course, you have to change voice mail greetings if you have VM, etc etc.
Any other system, or the programming involved in a software swap if numbers, requires the model number of the SYSTEM instead of the phone. If you need further help, comment back to this post.
Carl
Posted on May 23, 2009
Panasonic kx-t7730
What are you using to program.
PT Programming or you are using a PC Tool?
Did you save after setting names?
Jan 02, 2014 | Panasonic BTS Panasonic KX-T7730 White...
How to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
Nov 26, 2011 | Panasonic KX-T7730 Corded Phone
I am using Panasonic KX-T7730 i could not make out going calls wich strarts by " 0 " i change my phone but the problem is still there My extension number is 114 we are using pbx system
Is your extension programmed to allow dial 0 calls? The phone is just an instrument, it has no programming. Guess where the program is and who controls it? Yep, see your system administrator.
Carl
Apr 14, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
How do I change the extention names on KX-T7730?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Names
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
Jul 17, 2009 | Panasonic KX-T7730 Corded Phone
How do you program a Panasonic KX-T7730?
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
Thank you.
May 18, 2009 | Panasonic KX-T7730 Corded Phone
Change Extension No's
You have to go to your phone switch, I believe that all Panasonics are modular connectors. Look for a label that will correspond to your extension number. Find your other extension and then unplug and plug.
Cheers.
May 13, 2009 | Panasonic KX-T7730 Corded Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic Adv Hybride System KX-T7730
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
161 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
