Question about LG DLE2512W Electric Dryer
Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom 3 connections)
Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom connections)
    President:
  • 331 Answers
If you have the newer style, you should have 4 wires on the CORD <--- not the terminal block itself. They'll be; Black, White, Red and Green. The green goes to the frame/cabinet and the white ALWAYS (ALWAYS) connects to the center terminal. The Black and the Red attach to either of the 2 remaining terminals... doesn't matter which one.
If you have a 3 wire cord, don't worry about a green wire. Just wire it "black, white, red" or "red, white, black"... just make sure you put the white in the middle. Think Oreo cookie.
And to be specific about your question... The Black and the Red are the "hot" wires... each one carries 120VAC.
SG
Posted on May 23, 2009
  • Tracy Farrell
    Tracy Farrell May 23, 2009
    Thanks for the rating!
    SG
Going from a three wire cord to a 4-wire cord. Drier has 3 connection points.
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
If you found this helpful please leave thumbs up
Jan 08, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have the 691pass&seymour toggle switch/outlet, the way the electric was wired over 40+years ago does not look right? but I would like to install this new switch. on the old switch on the right side...
Thank you for the clear description of your P&S device.
You need to test your wires.
We are looking for the Hot, Neutral and Load wires.
Your old switch has two wires.
One of these wires is the Hot (I suspect 100% that the wire that comes from the other wires that are twisted together is the Hot)
The other is Load
Separate the old switch wires and turn on power.
Use ordinary tester.
Test each wire to metal box and see if the box is grounded.
Tester will light up on Hot wire.
You can also test each of the old switch wires to the other wires in the box.
1) Hot: Once you determine the Hot wire, this wire will connect to the P&S device:
Hot connects to the brass screws on right side, just as you said ... and these screws are on opposite side from silver screw.
2) Load: The wire to Load connects to brass screw on top left, which is on same side of device as silver screw. This screw sits opposite the P&S switch.
The last wire is the Neutral.
Test your Hot wire to all other wires in the box.
When the tester lights up, that is the Neutral
3) Neutral connects to silver screw which will complete the circuit to the P&S receptacle.
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Nov 08, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
How to install a 3 way plug for stove
If I understand correctly, your stove plugs into the wall.
Your stove plug looks similar to one shown
Review wires inside wall.
There are 2 hot wires which are red and black
There is 1 neutral wire which is white
And there is a bare ground wire
Connect wires so they match image above.
2 hot wires, black and red go across from each other
White neutral connects to flat prong on top
Bare ground connects to round prong on bottom
Older wiring might not have both white and ground ... if you do not have both, then connect the wire you have to the flat prong on top
Oct 09, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 | Dryers
I am changing out the wiring from a 3 wire to a four wire. The terminal block has (top to bottom) black, whiteandblue wires. The new 4 prong wiring has a white black green and red wire... what goes where...
The black,red & blue wires are your hot (120 volt) wires. Two of them get conn. to the two brass colored screws. The white is the neutral wire which conn. to the siver screw. The green wire is the ground wire conn. to the green screw which is the grounding screw.
Oct 06, 2009 | Dryers
Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Jun 12, 2009 | Dryers
Maytag drier de7600 connected new power cable to the 3 prong terminal on back of drier ground wire to the middle prong and the other wires to first and last. Drier does not start. What's wrong
check the breaker and make sure youturn it all the way off and all the way on. if you have a volt meter check the voltage from the two outside legs you should have 220volts
May 28, 2009 | Dryers
Wiring a 3 wire dryer wire into panel box
Stick her under the neutral buse, the groung and the neutral are connect at the panel anyway.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
LG DLE2512W Electric Dryer Logo
122 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
