SOURCE: pocket loox t830
I had this problem. Only solution is a full Hard Reset which is a combination of Power Switch Photo Switch and Reset Switch. BUT you will loose everything on the PDA.
SOURCE: WM6 for T830 Pocket Loox
Still BETA but WM6:
http://forum.xda-developers.com/showthread.php?t=336328
SOURCE: no connection with pc
Try loading the ActiveSync program onto your computer again. I have found this works most times. Also once loaded you have to place the T830 in the cradle for it to register as being connected. Check your type of connections to the PC in the program options as well - USB is the best, you may be on a Com port that is not recognized.
SOURCE: I want to change language dutch to English in My
ALL YOU HAVE TO DO IS LOOK IN THE BOOK THAT YOU GOT WITH YOUR PHONE IT WILL TELL YOU STEP BY STEP AND IT WILL ALSO LET YOU SEE THE ORDER SO YOU CAN CHOSE ENGLISH.
