Question about Panasonic KX-FLB801 All-In-One Laser Printer
Need a additional driver file for Windows 7 operating system supp
My new operating systems is Windows7, New os doesn't accecpt the old panasonic KX-FLB852 , driver file. could you pls send or support file immediatly.
  • 118 Answers
I don't know how this will help but you can try here
Posted on May 23, 2009
HOW CAN I PUT A NEW OS ON MY LAPTOP THAT I PUT A NEW HARD DRIVE IN
You can't copy the operating system from your PC to your laptop. However, you can install a new operating system which is Windows 7 64 Bit which is the same with your PC. You have to have the DVD (Windows 7 Installation Disc), drivers for your laptop, and the DVD for the programs that you want to add to your computer.
Before installing a new OS to your laptop, make sure that you have saved all the important files to an external saving device such as a USB flash drive. You have to make sure that your laptop has all the specs to run Windows 7. Please visit the link below to check the minimum requirements (system) for Windows 7.
http://windows.microsoft.com/is-IS/windows7/products/system-requirements
Hope this helps.
Nov 14, 2012 | Microsoft Windows Vista Ultimate Edition
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Some files donot opening
It Depends on OS Windows XP is compatible to all games. It Depens on software Operating System requirements Windows 7 are not full functional to some files they cannot open it. Some old files they cannot open to new OS Try to change your OS to Windows XP2
Feb 28, 2011 | Computers & Internet
Installing windows7 os
When you build a new computer you will need to install an operating system (OS) to it; alternatively, if you are upgrading an old computer you may want to install a new OS. Installing Windows 7 is easier than installing any previous Windows operating system and can be done with just one DVD. This process can take up to up to an hour or more depending on the specifications of your computer.
Instructions
1. If you are upgrading and have a previous operating system installed, back up your important files to external media.
2. Turn your computer on and insert the Windows 7 disc.
3. Press any key when prompted to boot from the CD.
4. Click "Install Windows," "I accept the license terms" and then "Next."
5. Click "Custom." Select the empty partition you want to install Windows to. If you are upgrading, select your existing operating system, click "Format" and then click "OK." Then click "Next."
6. Follow the remaining onscreen settings to set your personal installation preferences. Click "Finish" at the end to finish the installation of Windows 7.
7. If you backed up files in step 1, copy them to the new folders such as "Documents," "Pictures" and "Movies" as appropriate.
Feb 22, 2011 | Computers & Internet
I would like to remove Windows7 and install Windows Vista. How do i remove Windows7? Thanks
Hi ,
Just launch the Vista install disc , it will automaticaly erase Windows 7 and install a new fresh version of Vista .
Caution : Back up your data and especially the drivers before proceeding .
Best regards .
Feb 10, 2011 | Computers & Internet
Powershot A470. used to be able to download pics with no prob to my computer. Got a new pc Samsung with windows 7 (RV510) but for some reason it cant download to my old pc either.. just seems its not...
Windows7 usually use x64 bit system operation, drivers which run in windows XP or Vista can be uninstallable in Windows 7 because XP and Vista use x32 bit system operation (except certain series).
See your OS from Device Manager (Windows+PauseBreak > Device Manager), 32 bit or 64 bit. Then you can download the driver compatible with your OS from here :
http://driverscollection.com/?H=PowerShot%20A470&By=Canon
If this useful, RATE please !
Jan 17, 2011 | Canon PowerShot A470 Digital Camera
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Iam using SAA 713X T.V CARD for xp .now my p.c os changed to windows7 but t.v card not working.how can i fix this problam can u help?
You just upgrade to new Operating System i.e. Windows 7. So all devices like Tv tuners cards etc. have different drivers for all operating systems . So you have to install the drivers of your Tv tuner card which is compatible to windows 7. Go to www.driversguide.com or go to your Tv tuner card maufacture site for drivers.
Aug 15, 2010 | Computers & Internet
I can not install this printer in windows7 operating system
Hello.
Unfortunately, Xerox doesn't yet offer Windows 7 support for your device. However, they announced a release of the Windows 7 driver until June 2010.
Still, you can try installing the Windows Server 2008 driver:
http://download.support.xerox.com/pub/drivers/6110MFP/drivers/win7/cs/Phaser_6110MFP_W7.zip
Source:
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/win7/en/Windows7_Matrix.pdf
Now ... are you sure your device is not 6110MFP? Because Xerox Phaser 6110MFP does have Windows 7 support and you can download the driver here:
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
I am using toshiba l310 laptop with windows xp installed onit.NOW I WANT TO CHANGE MY OPERATING SYSTEM FROM XP TO WINDOWS 7,MY QUESTION IS THAT CAN I USE SAME DRIVERS FOR WINDOWS 7 WHICH I USE ON XP ...
You will need new drivers for Win 7. Before attempting to go to Win 7, run the Microsoft Upgrade Advisor and see what issues it lists: http://go.microsoft.com/fwlink/?LinkId=161223 (since laptops have on-board video that may be an issue). You will be doing a custom install from XP and have to reinstall all of your programs and drivers - many will be available. Several XP programs will not install in Win7 without some work (compatability mode or the XP mode virtual machine (in Pro or Ultimate). Upgrading your software may be needed unless you have the latest version that supports XP through Win7 or want to do the work-arounds.
In addition you would be wise to check for any BIOS updates for your specific machine and apply those. Windows 7 is a good OS if you have 2 GB or more of memory. It can run with less but it isn't better than XP in that case. The biggest difference is that Win7 will be supported by Microsoft for updates for a longer period (patches); XP will lose that support in the next few years.
I hope this helps.
(I converted an XP desktop to Win7. However, my video card could handle the OS and I have 2.5 GB of memory and a Windows Experience Index of 3.9 from the system.)
Feb 15, 2010 | Computers & Internet
Panasonic KX-FLB801 All-In-One Laser Printer Logo
309 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
