Question about LG Heating & Cooling
WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
I DONT HAVE ANY IDEA WHAT HAS HAPPEN WITH MY AIRCON WHEN WATER LEAKING FROM MY SPLIT TYPE LG AIRCON THIS PAST FEW DAYS. IT DOESNT STOP DRIPPING WATER INSIDE MY ROOM UNTIL I SHUT IT DOWN. I GOT AN IDEA THAT MAYBE THERE IS SOMETHING THAT I PRESS ON THE REMOTE THAT MADE THE LEAKS OCCURE...IM NOT WELL FAMILIAR WITH THE SIGNS & SYMBOLS APPEAR ON THE REMOTE SCREEN..
KINDLY HELP ME WITH THIS PROBLEM.. TNX But if water stagnates, it will damage the machine inside which basically made of metel. Splinters of water fall out when the Split Aircon is switched on at any temperature.... There should be another reason for it and this has to solved. Only LG is having this problem. Others are not having this problem. Can you help me out first with the reason and then solution
Johan
    Guru:
  • 1,524 Answers
You have a clogged drain.
Posted on May 23, 2009
  • melvin solis
    melvin solis Dec 08, 2016
    call me i fix that 09215038115
Water leaks from my split type non inverter air con?
Posted on Apr 03, 2013
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
Turn on LG aircon inside house. Goes for a short time them c5 comes up on screen and the aircon stops. Compressor has been noted to start and stop
C5- Indoor to put door communication problem.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
HI my samsung split sytem aircon is dripping water on to my carpet? only just started today. Richard
Check outside for the drain hose and make sure water is draining.If not, disconnect hose at evaporator ,and blow it out. Do not **** it from the open end: it does not taste good.
Feb 23, 2010 | Dehumidifiers
Need remote for a v-lec split type air conditioner
Why not try the dealer selling V - lec aircon? They are
in the best position to know where to get the replacements or clone remote controller for your unit.
Better still try surfing the internet, V-lec Aircon may have
a web site to service their clients. May this info, help you.
Jan 06, 2010 | Heating & Cooling
Samsung twincooling icemaker leaking water & overfreezing
probably the water valve is not shutting of completly . this will flood the tray and then run over into the bucket. try // i would replace water valve . if this does not correct prob. replace the ice mker head as it time's the fill..
Dec 11, 2009 | Washing Machines
My split type aircon wont work properly, water keep dripping
try cleaning the port for the drain plug, when the air is damp outside it will condence a large amount of water. Aslo make sure unit is level so it will drain properly.
Jul 19, 2009 | Fedders Heating & Cooling
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Water dripping from split level aircon on to floor
this time of year it's either from your humidifier or if you have a high effeciency furnace it's because the water isn't draining where it's supposed to.  you need to get to the furance or air handler and make sure the drain line is where its supposed to be.
Nov 29, 2008 | Heating & Cooling
Water leaking from water dispenser
replace your water valves one for the door disp is leaking
Feb 16, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Heating & Cooling Logo
1,087 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
