Question about SanDisk Sansa E280 MP3 Player
Scandisk e280 could you please help me? my scandisk is stuck on the scandisk screen. also it won't turn off can you help me
  • dman1873 Nov 03, 2007
    i press the power button the thumbwheel lights up and stays lit. but nothing else happens.. i tried removing battery but didnt work. it does the same thing after i reinstalled the battery.
  • mench Nov 13, 2007
    My e270 was stuck on the Sandisk screen and would seem to intialize then turn white and back to Sandisk screen. I did run the recovery tool and that seemed to work fine - reformatted and all. When I turned it on it went to Sandisk screen then went to normal menu saying Refreshing Datat but then went back to Sandisk screen again. Now it is stuck again on Sandisk screen. Should I try doing firmware stuff?
  • 626 Answers
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 22, 2007
My ScanDisk cruzer micro 2.0 stop working. The orange light won't turn on and no respond. I don't need to get another ScanDisk. I just want to have all my documentations. Is this situation fi
I would try several different USB slots if you haven't already. Unfortunately, if it doesn't light up, there's not much you can do, other than take it to a specialist. Sorry.
May 02, 2012 | Computers & Internet
Stuck on the opening screen
try going to safe mode first... upon turning on your laptop, continuously press/ hit F8 key until it gives you options then select safe mode... after you're able to log into safe mode you can try and run a scandisk check or try to restart the computer to see if it would work in normal mode...
hope this helps you...
Nov 15, 2009 | Acer Aspire One PC Notebook
Hung ipod
Hold the power button of your Sansa for 15 seconds, this will reset and power down your device, after which it will power up normally.
Mar 27, 2009 | SanDisk Sansa E280 MP3 Player
Key Lock Sansa e280
on the top is a switch that says lock /unlock ......... switch to unlock
Dec 18, 2008 | SanDisk Sansa E280 MP3 Player
E280
Please visit this forum and follow the steps there...
http://www.anythingbutipod.com/forum/showthread.php?t=11233
I hope that help..
Please rate accordingly
Thank you
Computerrep
Oct 02, 2008 | SanDisk Sansa E280 MP3 Player
My e280 sansa mp3 player is not working.....help please....
There is a problem with the device firmware itself..you can try to reset the player by holding the power button down for 15-20 seconds or until it resets....the latest firmware for the e280 resolved much of the freezing issues....also there are two modes for you to use the e280 the msc and mtp.....try deleting in mtp mode....if that doenst solve it...just go to the sandisk site to get a firmware upgrade done...and that would solve the proplems..
Jan 02, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280
the e280 8gig it doesn't come with a cd instalation, it only works for transfer music in media plalyer 10 or 11 sync. another way to tranfer his drop and drag to do this open my computer then open the device u will see file just as music,photo, videos drag and drop the musica files into the file. if poppoed up apear it happen to me too the only thing i did was switching usb ports to a diffrent port. www.scandisk.com for and updates select downloads. it will said drivers downloads select sansa firmware updates but before it has to be unplug. when download finish u need to restart then plug e280 open sansa update in desktop it will show u e280 if new updates are availble. also check the system requierments for compabilities. hope this help if not u can contact sansa coparation there listing in support. hope this help,
Dec 16, 2007 | SanDisk Sansa E280 MP3 Player
Frooze
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 19, 2007 | SanDisk Sansa E280 MP3 Player
When i plug in my sansa e280 it shows the booting screen turns white, and boots again
It sounds like you have a virus or some sort in it. If you still have a warranty send it back in and get a new one. It sounds like you have been doing exactly what you are supposed to be doing. The only thing that I could think of is that it is the motherboard. that is going to cost you about $91 Thank you, Connie
Jun 24, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e280
Hold the menu button down for about 15 slow seconds, should work.
Jun 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
