Question about Sherwood RVD-9090R
Sherwood RVD-9090R Left Rear Channel Failure
Left rear channel died and won't play test tone or anything else. The wiring is OK. I substituted a known good speaker and still no sound. I am wondering if there might be a separate speaker/amplifier fuse for each channel. If this is a possibility, I will crack the case to try replacing the fuse. It's been a great receiver and I'm not in a position to replace it at present. I am handy and somewhat fearless in fixing things. Any help will be much appreciated.
  • 33 Answers
Its due to your player there is nothing wrong with fuse... don't crack the case...try this just connect M1 & M2 to the aux input of your home theater
Posted on May 23, 2009
I need user manual for a sherwood RVD-9090RDS
hi,
I have the user manual for sherwood RVD-9090RDS with me. As it is pdf file i can't sent the same through the Fixya. If you can provide your email id then i will sent the same to you email address.
OK
Sep 11, 2011 | Sherwood RVD-8090R Receiver
I have just buy a old shewood rv6030r but i want to know its power .May someone can tell me about it Thank you first
Search engines find these answers immediately without involving 'experts'.
According to this:
http://www.echipamenteaudio.com/tag/rv-6030r
Power Output Continuous RMS at 8 ohms 100W + 100W
Rear Channel power output at 8 ohm, 20W + 20W
Central Channel at 8 ohms, 65W
Jun 29, 2011 | Sherwood RVD-7090R
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Having trouble with a jvc kdr610. Just purchased from best buy. Hooked up with a gm wiring kit so all color codes are right. The left front channel is ''dull'' I tried switching the speakers from left to...
Well, very common with JVC's to loose channels, JVC's tend to burn out or, skip, or their channels die out. Easiest fix is to replace it with a Sony or Pioneer but if not an option then use the rear left channel to run both left front and left rear speakers. Wire the left front + and left rear + to the solid green rear + wire on the car harness adapter and the left negatives to the green w / black rear negative channel wire. This will be a temporary fix but you need to fix or replace the radio otherwise the speakers will draw aheavy load from the rear left channel of the radio and probably overheat or burn out on you with long time hearing or at high volumes.
Good luck.
Please rate and vote if I helped. Thanks.
Jun 17, 2010 | Car Audio & Video
Sony STR DE845: rear speakers not working, three fronts are OK.
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Sep 05, 2009 | Sony STR-DE845 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
No power
my be the off/on bottom is not good.no working.
Jul 28, 2007 | Sherwood RVD-6095R Receiver
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
Sherwood RVD-9090R Logo
325 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
