Question about Motorola Mobility H700 Wireless Headset
After i enter my passkey it says connection failure for my h700 blue tooth
I enter my passkey for my blackberry storm and it says connnection failure to the h700
    Scholar:
  • 65 Answers
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
The passkey is 0000, four zeros.
Posted on Jul 30, 2009
Changed phones want to install blue tooth h700 but it asks for a passkey. Where do I fibnd the passkey?
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off, you want to have the H700 fully charged up and it's probably good to have the PHONE fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for available units in the bluetooth frequency spectrum and hopefully find your H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan another time or two. Also make sure that the H700 is still showing purple, not blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so don't stop here. Select the H700 and you'll be asked if you want to bond the two units:
You want to say "YES", of course, at which point the PHONE will ask you for the bluetooth passkey of the H700, which, like all Motorola bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple "pairing" mode but has switched to the regular slowly flashing blue mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please remember to vote 459e9de.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Motorola Mobility H700 Wireless Headset
Trying to sync with my blackberry 8900 asking for numeric passkey for my plantronic 220 ... dont think I needed this when I had a Motorola Razor.... annoying.... any thoughts.
the passkey is just like a password which is a single time entry into your phone for connecting blue tooth devices in a secured way.
once you enter the passkey the phone will be able to identify and connect to your device each time you search for blue tooth devices in the phone.so please do not get annoyed, go ahead and give a passkey of your own choice(like birth date. so that you wont forget it easily since you wont use it again until you reset the phone or connect other devices).
this passkey can also be used to connect it to laptops, desktops if they have blue tooth.
also remember this passkey is used to restrict any unauthorized access to your phone.!!!
should you have any questions please write to us again.thanks for contacting fixya !
Oct 23, 2009 | Plantronics Explorer 220 Bluetooth Headset...
What is the passkey to my sony vaio laptop VGN-CS160J
If you have a blue tooth device added to your laptop or build into your laptop, you will have to enter control panel and select Classic View at top left and then select Blue Tooth.
Once you are in that option window you should go to security and set your passkey there and then. When you apply your settings and return to Pair your devices you only need to use the passkey that you have entered at your blue tooth security and you should be all sweet.
Aug 23, 2009 | Sony VAIO VGP-BMS33/B
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
Jul 24, 2009 | Motorola Mobility H700 Wireless Headset
Blue tooth connection passkey
Most Bluetooth devices uses '1234' or '0000' as the default passkey. Since you tried using '0000', you may wanna try using 1234.
Have a great day!
May 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
Pairing my blackberry curve8310 to a motorola H700 headset
when pairing a handsfree device to your phone the typicaly generic passcode is 4 zero's (0000)
Mar 12, 2009 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
865 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
